Table Top Finish advice needed
Howard in Bethesda
>I�m making a kitchen tabletop and have a choice of using any of the following finishes:
Deft lacquer spray can
Barleys Gel Varnish
Or
General High Performance water based topcoat
Is any one significantly more durable than the others?
I do not mind doing 10 or 15 coats of the gel varnish.
Thanks
Howard
Re: Table Top Finish advice needed
>IMHO,
"86" the Deft. It's a very low solids lacquer that will not hold up.
A good varnish properly applied with take a lot of wear and tear because its film is flexible. 3-4 coats, dried and sanded between, should be enough depending on your wood.
That said, I'd go with the General Hi Per. Great stuff, KCMA approved, levels beautifully. Best applied by HVLP, but brushable so long as you don't overwork the wet film.
Dick Coers
>I agree completely with Mark on the water base. Deft would be an absolute disaster. I've seen that stuff melt into a desk saver! It would water mark very easily, and getting a good finish from a spray can is next to impossible.
Another brushable alternative
>A waterborne poly floor finish. Varathane and Benjamin Moore both work well. Tough enough to walk on.
Clint
Pete LaBelle
>Have 5 coats of Minwax semi-gloss polyurethane on my oak dining room table. Holding up fine. No finish will stand up to sharp objects pulled across it though.
You can brush it on with good results. Don't let your shop get too warm. Warm & dry shops speed up evaporation of the solvents. Use a large brush and work quickly to spread the varnish, then leave the room. A smaller brush, slow work speed, and warm shop will allow the varnish to start to thicken, thus brush strokes become permenant. Work from one end of the table to the other. Don't go back.
