THE WOODRAT IS BACK!
Boiled Linseed Oil on Cherry *LINK*
Ken Krawford
>I've always been a huge fan of Thomas Moser and love the warm, rich look of his finished pieces. An article in This Old House magazine stated that he sprays 2 coats of boiled linseed oil heated to 130 degrees and then follows that with carnauba and beeswax over the cured oil.
I'm sure they've left some things out of the description but my main concern is cherry's tendency to blotch. Fine Woodworking recently advised a wash coat of dewaxed shellac to prevent blotching but I doubt that the oil would penetrate.
Any thoughts about the Moser process or other ways to achieve that type of finish?
Thomas Moser
Re: Boiled Linseed Oil on Cherry *LINK*
>Ken,
Since cherry has differing densities, you can, indeed use a wash coat of shellac to even out absorption of the oil. An application of BLO has been part of my cherry finish recipe for years. It calls for sanding to at least 220, then application of a 3/4 lb cut coat of dewaxed shellac, then a light resand with 220 followed by the BLO. I don't however, use 130� oil. I do 2 applications about 4 hours apart with the second application wet sanded with 320 w/d paper, allowed to sit for 15 min, then wipe off to dry. I then seal under 1-1/2 lb shellac and topcoat with the clear of my choice.
Wax gives a lovely leather-like feel, but it's too fragile to work for me as a finish on an item that will be used.
mm
>You can get the same effect with less rigamarole by spraying several coats of thinned solvent lacquer, NC or CAB, rubbed out with 0000 steel wool and Butcher's wax. It's more resistant and just as rich looking. BLO is superfluous.
Clint
On the Thomas Moser Question...
howard
>I work in manhattan and have gone to their showroom. I can honestly say that, first, I could not believe what they are charging, and second, any one of us could build the same pieces. My point, if they are holding themselves out as something extraordinary, I would think they'd be building in a way that most of us would not be able to!! Just me I guess.
Re: On the Thomas Moser Question...
>Moser had a highly marketable idea developing a Shakerish non-threatening line of furniture that appealed to the nouveau arts & crafts crowd. He's now expanded the design menu by plagiarizing Nakashima. It's all factory-efficient stuff with minimally demanding finishing that looks good at 25 feet, offering little of the refinement of the historical precedents.
It's all about marketing.
Clint
Why is it that....
Bill Tindall, E.TN
>people pay a large premium for figured maple and mahogany and then stain it to enhance this figure? But when it comes to cherry this same figure is called by some "blotching" and great effort is spent trying to avoid it.
If one is striving for a uniform red look then use soft maple and stain it with cherry stain.
I believe that most of the problems finishing cherry are due to improper sanding.
Re: Why is it that....
>My guess is that the "blotching" in cherry is caused by the varience in grain density leading to differential absorption of whatever is put on it. The greater the differential, the moere pronounced the "blotching", and the thinner the finish liquid the greater the differential in absorption. All stains will tend to promote "blotching". A film finish like shellac or lacquer, applied to the raw wood, is absorbed very little, so "blotches" less.
Clint
Z'actly
Re: I disagree...
slashdev
>IMHO, I *think* the "blotch" in cherry is variation in grain direction, not density. You can get the dark areas to go light (and vice versa) just by looking at the cherry from different directions. 'dem little photons get absorbed when 'deys runnin' down 'da grain. But maybe there are boards that do have density issues. Sometimes I'm bored, and I have density issues... :)
BTW, I agree with the OP. Why is it called blotchy? It's not exactly regular, like curly, I suppose. Although I wouldn't like large areas of contrast, it seems like it's usually on a small scale. Except around knots, that is.
FWW recently had an article on eliminating the blotchiness. Nice, even, light reddish-brown color with hints of yellow. I wonder if customers would be happier with Formica. Go figure.
No, wait... It's *figure*. ;)
