routing small piece
eliot d
>What's the best way to safely rout a cove around the perimeter of a 1/2 inch thick odd-shaped work piece that's about 8 inches long and about three inches wide?
routing small piece
eliot d
Re: routing small piece
Jesper, Denmark
>Router table and extreme care.
Carol - now back in Dubuque, IA
>Routing table and bearing guided bit.
Never place your hands where the bit will go or where it COULD go.
Fred Davis
>Eliot,
the suggestions using a router table with a flush bearing cove bit are the way I would go , in addition to that I would use one of the handled holddowns I use to to hold the face of boards down on the jointer when I flatten them.
Never would put my fingers that close to a bit doing 22,000 RPM
FredD
What I do!
Lee Schierer - McKean, PA
>When rounting small pieces, I attach them to a larger piece of material with double sided tape so the surface I want to cut is exposed. The larger piece of material gives me better control and keeps fingers away from the bit so that if the cutter grabs that my fingers are away from the cutter. I also tend to use a fence, even on piloted bits when routing the straight edges of small pieces.
Lee
>>Never place your hands where the bit ... COULD go.
I read some advice I thought was good: Think about where your hands or fingers could go if the wood suddenly disappeared.
Jim Dillon
>Eliot,
As others have suggested, using a router table with some sort of "hold-down" to both hold the small piece of wood, and to make it "larger" that what it really is to give you more control over the piece is one option. Here is a pic of such a setup thrown together quickly to get the job done in a safe manner. I used double-side tape to hold the small piece down, as well as two end blocks held in place with a couple of brads.
However, you said your piece was irregular in shape. For that, I've had luck with this approach. Cut a slightly smaller scrap flat plywood piece thick enough to raise the work piece high enough that the router bit bearing clears the bottom piece. Then, using double sided tape, tape the work piece to the scrap piece, and then tape the two pieces to a much larger flat piece of scrap plywood. Place your router on top of the work piece and slip a scrap piece of wood equal to the combined thickness of the work piece plus smaller scrap piece. This will act to stabilize the router. Then have at it. Hope this makes sense. Double-sided tape is your friend here and I always keep a roll on hand. Hope this helps.
Jim
Kneale Brownson dreaming of snow in N. MI
>How about the small pieces holder device sold by Rockler:
Or the Grrrrippppper system?
