Lock miter router bit Q *LINK*
Denis Ch�nard, Orl�ans, Ont.
>I bought one of those to assemble large legs from thin stock. The instructions state that two of the pieces are milled one way (say with the piece vertical) and the other two milled the other way. That ends up similar to pin vs. tail boards in dovetail drawer construction.
While this setup makes sense when making drawers, I am making legs so this doesn't matter to me. I was inclined to make each piece with one "pin" and one "tail" part. Any reason not to do this?
Thnx,
DC
Lock miter bit (click on "Instr" at the bottom)
Re: Lock miter router bit Q *LINK*
HC Sakman
>Hi Denis,
If the boards were joining edge to edge, all the pieces can be fed horizontally, but when the adjoining piece is mitered to the other, you need to mill the face that's mating with the horizontal piece, which is at 90* in relation to the other piece. Nothing to do with tails and pins, which are different shapes fitting together. With lock miter bit, same shape fits the other exact shape at 90*. That's all.
Chico...
Bob Lemon Sacramento Ca.
>Denis, if you are planning on having tapered legs, all the milling should be done in advance. You may already know this, but this is just a reminder. Also watch the orientation of the boards to each other and how the light will reflect off of them. Good luck! Bob
Fred Davis
>The instructions are correct , run the same pattern (male) on both edges of two boards and the other pattern (female) on both edges of the other two boards.
Why try to reinvent it?
FredD
Robert R Clough - Thorncraft
>Never having done this for legs - I do use lock mitre for boxes - perhaps the following is unworkable.
I know that mitre joints are not the strongest when glued, but would epoxy work here?
Yes There is a reason.
Keith Newton, LR, Arkansas------WebKitFormBoundary
>I think most of the previous responders missed what you were asking.
When it comes time to glue and clamp them together. If you use clamps, you will only need to clamp from two sides if you run both pin on two of the boards, and the opposite on the other.
If you run one side with the face to the table then the other to the fence, then you will need to clamp both ways. But maybe you can just bind it with stretch wrap like for packing, however I don''t know how good that would be if the joints don't close good, and it would interfere with clean-up of glue, and hide any openness.
Therefore, I would suggest that you do two sides to the table, and two to the fence, then clamp the way the tongues point, or from the fence run sides.
You probably already know to set the center of the bit profile to half of the thickness of the stock. These bits are tricky to set up when you have never done it before. There is probably a nice tutorial somewhere if you don't have one.
Fred Davis
>lock mitre joints when glued ,are very strong because they have a larger glue face then other joints.
FredD
lock miter joint movie
del schisler
>go here to see about the lock miter joint and many others I use the bit for some things del
http://www.mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/instruct.html
