Bowl Blanks
Bowl Blanks
Bowl Blanks
Kelly M. Robison
>Help, I am a faily new at wood turning; but I love it. I've been making saw dust for 40 years and recently turned to "turning" because a friend thought that I might like it. I have a nice lathe with variable speed. I have made some real nice stuff; mainly with store bought wood. Somebody gave me an old maple tree that had been on the ground for about 2 years. I tried making some bowl blanks with my bandsaw. When I tried to turn them on my lathe at slow speed [500 to 800] to keep the vibration down; I am using a roughing gouge; I am tearing the fiber instead of getting a nice smooth cut. What am I doing wrong?? Is there a special tool for cutting end grain??? I know that I have to get it in a rough cyclinder shape before I can start to shape it. How do I do safely??
Kelly M. Robison, Port Orchard, WA
Re: Bowl Blanks
Post over on the Turning side for better answers
>Speaking as an occasional bowl turner (and frequent spindle turner) - don't use a roughing gouge - use a large bowl gouge. Presentation of the tool edge to the piece is everything (well, sharpness is also - but that's another story) - you have a better chance of slicing the fibers with a bowl gouge and proper presentation.
Re: Bowl Blanks
Re: Bowl Blanks *LINK*
>As JL said, the sharper the better. Also, the smaller the gouge, the smaller the bite it can take and the smoother and less traumatic it may be to get it round. Of course, the gouge must be large enough to be sturdy, so something like 1/2" is often perfect.
You didn't say how large is your blank. People who turn REALLY large bowls often use special scraper tools with very thick shafts and 1/4" round or pointed tips, i.e., check the Tools page at http://www.olandcraft.com for an example of some tools that work well on a large turning.
Along the same line, I sometimes use a very sharp spear pointed scraper to knock off the rough. Using just the very tip can cut gently on even the roughest blank. (there is a reason that lathe duplicating machines use such a pointed tool)
To round safely, get it as round as possible before turning on the lathe. A bandsaw helps a lot, or even a chain saw (with the lathe off). Look at the link below about trimming excess on the lathe before turning it on.
Also, when cutting a rough blank, to avoid beating yourself and the equipment to death, don't attack the corners directly but sneak up on them but making smoother cuts from the ends. I don't worry about tearout until the blank is round and shaping is in progress. Tearout can then be controlled with sharp tools (extremely sharp, shaving sharp), cutting in the appropriate direction, taking very light cuts, treating the wood with something like wax, oil, sanding sealer, or CA glue, and using shear scraping or even cabinet scrapers in some situations. Lately, I've had success with a special tool made by Mike Hunter: a very sharp round tungsten carbide cutter which does wonders on end grain in many cases.
And yes, if you post on the Turning board here you might get better answers from "serious" bowl turners.
http://www.olandcraft.com/Big_pieces/Main_Street_M
