Library table finish
DocJim...Fayetteville, NY
>Hi all,
What are some favorites you would use to finish an oak library table I made for our church? Quick and easy would be nice. I was thinking a few coats of a gel poly.
Thanks,
Jim
>Hi all,
Thanks,
Jim
Re: Library table finish
Bill Tindall, E.TN
>If you are going to get into this kind of work learn to spray. This kind of product would get finished with a conversion varnish- very durable.
Fred Davis
>Since you said it is for your church , and a quick and easy finish, I am not sure whether Bill meant pray and said spray or .....
FredD
Waterborne poly floor finish
>A lotta angels could dance on that.
Clint
Re: Library table finish------WebKitFormBoundaryAA
DocJim...Fayetteville, NY------WebKitFormBoundaryA
>Good idea, Bill. We do spray lacquer on our kitchen cabinets at Habitat (this table was technically a Habitat project between houses) but our construction manager doesn't want to get into spraying varnish.
Fred Davis
>If your already spraying Lacquer on your kichen cabinets, then your construction manager should have no problem spraying CAB Lacquer on the table , uses the same gear, same techniques and it is plenty tough enough for a table finish.
FredD
BILL White
>Ah Hah!!!
Quick and easy???? I've NEVER seen one of these. If it was mine, I'd fill the pores and use a wipe-on as was stated in another post.
Bill
