Dryin' time...
Dryin' time...
Dryin' time...
john l. blue
>wonderin' how long this piece of dogwood gonna take to dry,
cut it today, stripped the bark, it's a walkin' stick deal, the
handle is naturally curved, it's hanging up vertical now. Thanks
in advance! Blue
Re: Dryin' time...
Re: Dryin' time...
>Depends on the size and the environment. A thin piece stored indoors in an airconditioned/heated space will dry quicker and eventually to a lower moisture content than a thicker piece dried outdoors.
Dogwood tends to split, especially if thick and if dried too quickly. I've had some in the round split with a wide, gaping crack. But small diameters dried slowly usually did fine. I cut a lot of dogwood poles for trellises which didn't split, but I left the bark on which may have slowed the drying. I would certainly coat the cut ends with Anchorseal. That's the way I dry dogwood turning blanks and most survive.
Re: Dryin' time...
Re: Dryin' time...
Paul Waddle
>I cut some (already dead) dogwood ~3'' in dia,let dry for about a yr,coated the ends with glue-it still cracked open. I still used it however,just bandsawed down the split,glued it up and made a couple of good carving mallets... They are doing good after 2yrs usage. pw
Re: Dryin' time...
Cook it.
Basil
>We used to cut forked dogwoods to make slingshots. We'd place something between the forks and use haybaling wire to put the curve we wanted in the forks. Then we'd stick them in the oven and roost them for a while. It dries them out and makes them hold the curve you want. Smells like you're roosting peanuts.
....but a walking stick is probably to long for the oven. Maybe roost it over an open fire?
