TS switch . . .
TS switch . . .
TS switch . . .
steve mackay
>I've always scavenged parts before saying farewell to in-op stuff but I just put the last of my switch-stash on the TS. Up and running but . . . anyone found a readily available (Lowe's, Radio Shack, etc.) switch for replacement ? Don't need no safety key or frills, just on & off. Hate to wait 'till another goes bad and suffer down-time.
Re: TS switch . . .
Re: TS switch . . .
Bill Howatt
>I mounted a plastic electrical box on my saw and use a double-pole, 20A, toggle switch (looks like a regular light switch with the cover on) from Home Depot. These are good grade switches, not the 75c cheapies. My saw is about 9A, 240V and it has been running on the same switch for years.
Bill
Re: TS switch . . .
I LIKE that idea ! Thanks !
steve mackay
Re: TS switch . . .
Re: TS switch . . .
Chuck in ND
>I like the paddle switch, easy to find on the saw with your knee or hand. The original switch for this saw was mounted on the front of the saw cabinet lower left, it was a small toggle switch. I had to make a mount for the new switch to attach to the fence rail and extension wing. I bought the switch from Woodtek, it came with a plastic electrical box.
Re: TS switch . . .
Re: TS switch . . .
Chuck in ND
Re: TS switch . . .
Re: TS switch . . .
Chuck in ND
>Here is another saw that I kept useing the factory toggle switch but relocated it. Both saws the switches were mounted inside the dust generating saw cabinet, not a good place in my opinion.
Re: TS switch . . .
Dual switch
>I use the same switch (20A DP from HomeDepot) in a box mounted to the blade guard (Uniguard) arm, wired before the main switch which is mounted under the fence rail.
I can use either switch to power off the saw, depending on which is closer to reach. It's very handy.
Happy Woodworking!
Re: TS switch . . .
Switch/receptacle
Tom Dunlap
>Since my TS becomes a workspace I found that I needed power nearby.
When I rewired the switch I used a heavy toggle like the rest. I used a double box and wired in a receptacle in the other half. The TS becomes an extension cord eliminating another cord on the floor.
