Repair suggestions
Repair suggestions
Repair suggestions
Kneale Brownson dreaming of snow in N. MI
>I need suggestions for repairing the leg assembly for a 1950s era Baker Furniture Co. cabinet from the Finn Juhl collection. The first pix is the leg assembly removed from the bottom of the cabinet, which has a walnut structure and pecan veneers, so I think the legs are walnut. The loose leg in the upper right of the pix came from the damaged area in the lower left.
Here's a closeup of the damaged stuff:
The wood missing from where it broke off, letting the leg with dowel come off has been missing for quite some time, I believe. No sign of it where the cabinet sat until I started to move it and the leg fell off.
So, I have a couple of issues.
1. How would I reinforce the reinstallation of the leg with a new dowel and the intact good one? If I had the missing piece, I'd get it all together and glue it back on. I could try to find some walnut and splice it in place of some part that I'd cut off this assembly, but I'd rather not. The broken part goes under the back of the cabinet and generally wouldn't be visible when in use.
2. All the other legs will wiggle marginally. It's like all they used was a little glue on the dowels and none on the legs themselves. Is this possible? Should I try to heat the legs up to see if it's Hide Glue that I can take apart and reapply? I've no experience with Hide Glue or, for that matter, much with repairing stuff like this.
Re: Repair suggestions
Jesper, Denmark
Jesper, Denmark
>Kneale, this is basically a sick joint to start with. The leg is only held to the frame with the dowels. Glue on the junction between the end grain on the frame and the leg would have made very little difference.
The better way would have been to have a tenon on the frame ends and a mortice in the leg. I also doubt the wood is walnut. It looks like some secondary wood, maybe beech or soft maple, depending on where it was made. The frame construction is typical of the period from a design standpoint, but the construction smells of cheap manufacturing technique. The glue is most likely PVA, Not hide glue.
As I see it, you can eithe make a new frame with better joining technique or drill out the old dowels and re-do it as it was. An alternate as you cannot see it would be to use long screws in place of the dowels.
Couple possibilities
>If cosmetics enter into it, i.e., if it is likely to be seen, scarf a piece of maple or beech to the broken area and plane/sand it flush. Drill two holes for a couple serious screws through the leg and into the end of the rail. Reinforce the other three legs similarly, and plug all your counterbores. tain and touch up.
Or, you could make four new rails, complete with egg-crate joinery and coved ends, and reattach the four existing legs to that, this time using loose tenons instead of dowels. Or skip the coving and flatten the side of the leg where it meets the end of the rail. The coving adds marginal rack-resistance which will strain your joints.
