CAB LACQUER
RICK GETER
>CAN CAB LACQUER BE APPLIED OVER NITROCELLULOSE LACQUER ?
THESE ARE NOT WATER BASED.
CAB LACQUER
RICK GETER
Re: CAB LACQUER
Fred Davis
>Yes ,
Lacquers and shellacs are finishe's that burn into the previous coat of them.
That being said , the Gem Brand of CAB I use reccomends using over a vinyl sanding sealer which greatly enhances the water vapor barrier of the finish.
I use that sealer even tho I don't like it's sanding characteristics, as well as I lke regular Lacquer sanding sealer with out the adition of vinyl in the formulation.
FredD
Re: CAB LACQUER
>I have used CAB acrylic and NC solvent lacquers interchangably, sometimes one over the other with no problems. The two are, IMO, the easiest and most forgiving finishes available. They look great and provide all the protection fine furniture needs.
Re the comment about vinyl (or any other) sealer: They are unnecessary and add no value to the final product, and have the added liability of needing to be topped within a day, or so, of application.
All lacquers, and to my knowledge, any finish used as a topcoat is "self-sealing".
In most cases, solvent lacquer can go directly over stains and fillers without issue. If there's any doubt about compatibility, shellac can be inserted between as a barrier, but I've never run into that.
Clint
the reason vinyl is recommended
Bill Tindall, E.TN
>The vinyl sealer doesn't yellow. The main reason to use CAB is its non (actually less) yellowing property compared to nitrocellulose.
one caution
Bill Tindall, E.TN
>You are correct about the compatibility. I never use a separate sealer either. It is one more thing to keep on hand. If anything I may thin the first coat.
The CAB lacquers are formulated products, which is to say that the CAB is just part of the overall finish. The Sherwin William formulation is a bit picky about what it will stick to. I have had one instance where I got poor adhesion over a homemade pigmented stain dispersed in linseed oil. From then on I check adhesion on oil based stains and fillers. Perhaps the linseed oil was not sufficiently cured, or the formulation just didn't like going on top of linseed oil.
Re: one caution
>I've never had an adhesion problem with either CAB or NC, but then, I don't do any home cooking of stains. I use only water stains or well cured ZAR to get a tint. I've also dosed lacquer directly with soluble dye stain for a shortcut.
The only use I'v found for BLO is on shingles or an old farm wagon lawn ornament.
Clint
Re: the reason vinyl is recommended
>I think the primary reason to use vinyl is for a quick and cheap build in a production shop that's trying to keep costs down.
In my experience, Sherwin Williams CAB remains water white over time, and the amber cast of their NC also remains stable.
Clint
Fred Davis
>The reason Vinyl sanding sealer is reccommended by the MANUFACTUER is the same reason that before CAB came out you could and still can buy Vinyl pellets to add to NC sanding sealer to improve water vapor resistence.
FredD
Re: CAB LACQUER
Fred Davis
>It serves no useful purpose when a person like Rick asks a easy question to have the answer wander off into the areas generally reserved for folklore and urban legends.
Apparently you belong to the school of thought that a film finish like Lacquer does not need a SANDING SEALER or that paint does not need a primer.
Which of course is not true and does not help out the person with the question.
Sanding sealers are used under Lacquer and Varnish because they stand up the whiskers of the wood grain and greatly improve the sanding of the wood to a smooth surface that holds out the finish coat for a even application.
You talk about using Vinyl sealer because it is a cheap build , totally ignoring the uses of the sealer and the fact that using a more expensive finish as a sealer that not only does NOT perform like a sanding sealer , but is poor economics as well.
I have seen many woodworkers over the years do a excellent job of crafting a product , then skimp on the finish , hurrying it up, never realizing that a good finish requires a lot of time and effort just like the woodwork did.
One last myth killer , you can coat over a lacquer sanding sealer with Lacquer any time , there's no hurry, just like coats of lacquer, you get a chemical adhesion between coats of sealer and finish.
One caution about using sanding sealers is one coat is enough , more gives a soft finish.
As far as looking for a fast build of finish goes , thinner is better then thicker.
FredD
Re: CAB LACQUER
>Fred, perhaps your experience is different or more extensive than mine, after all, I only started using lacquer in 1973. I tried using Sherwin Williams T67 F3 vinyl sealer on a couple projects, and it added no value over straight CAB or NC lacquer. Moreover, contrary to your comment about an indefinite top coat time, instructions on the can say that the sealer needs to be sanded and top coated within four hours. It also says that if sanding within that time cannot be done a thorough sanding must be done "to insure optimum intercoat adhesion." So, according to the manufacturer, there is a bit of time dependency as well as running the risk of the topcoat peeling off.
The manufacturer does claim that vinyl sealer improves moisture resistance, but I say that if water proofing is the objective, a different finish is more appropriate.
Clint
P.S. I have half a gallon of vinyl sealer that's been sitting on the shelf for several years. You're welcome to it.
Re: CAB LACQUER
Fred Davis
>Clint,
the gem coatings and M.L. Campbell I use have a reccommended sealer which is a Lacquer solvent based sealer with vinyl added.
I never would use Sherwin Willams for a source of information finish. , they went down in quality many years ago and the stores are run by nitwits.
About ten years ago FWW ran tests on the holdout and water vapor resistence of teh Varnish , shellac, urethanes etc.
NC lacquer rated low , CAB over a Vunyl sanding sealer rated nearly as high as Poly.
Call me silly , but I am under the impression that water vapor rsistence is a main reason finish is applied to wood. rather it is Shellac, wax, paint or what have you.
perhaps you could update your reading .
FredD
Re: CAB LACQUER
>Fred, I always thought a finish was intended to offer some resistance to the accumulation of dirt and grime while improving the aesthetic characteristics of a work, unless of course, we're talking about a marine hull. Rare is the instance, except in Galveston, for a furniture finish with a lower perm than either NC or CAB acrylic lacquer.
Notwithstanding the quality of store help, I have absolutely no qualms about recommending my 20+ year choice of S-W lacquers, my current favorite being the Medium Rubbed Alkyd (without any sealer, of course). I spray the finish, not the clerks. My first reaction to using it was, "Why is it so easy to get such a great finish with so little aggrevation." Try it, you'll like it
Don't worry, be happy!
Clint
