failing eyesight
failing eyesight
failing eyesight
mike mcnerney
>As my eyesight gets a little worse each year, I am always looking for better lighting. What are other people doing? For me now I have to take off my glasses to do any close detailed work with really close task lighiting. Does anyone have any suggestions on magnifiers &/or lightweight head gear type lighting?
Mike McNerney, Ottawa
Re: failing eyesight
Paul Waddle
>I have double bi focals,this allows me to see things above and close up. Brownell's sell an item called an OPTI VISOR. It worked well for me for many years,then I took it fishing to tie on hooks-bad idea,it went over board. I was gonna replace it,but its gone from 25$ to 50$,so I'm holding out until there is a real need,then I will buy it again. I'm sure there are comparable products,but I know this one is fine. pw.
Jim in Burlington Ont.
Lighted magnifing glass *LINK*
>I have it mounted on the corner of my bench close by the vice. I also have a few magnifing glasses for small work purchaced them at the CNIB store. They are the most resonably priced and knowledgeable people around.
http://busybeetools.com/catalogue/page71.htm?page_no=+71
>I installed track lighting above my work bench (and lathe) - that gave me a bit more general illumination. I have a portable lamp with a par 30 bulb for more specific close in work.
The magnifiers are looking more attractive :).
Jason
>Harbor Freight has a cheap version of this for less than $10. I used it a few times and while the optical quality leaves a bit to be desired, it worked for short periods. You might take a look there.
