Holding power of Tapcons
wilbur
>This is a question that got discussed on the chat room last night, but I thought I'd toss it out to the rest of the brain trust.
I'm planning to use Tapcons to screw some 2x4's into a cinder block wall and then attach plywood to the 2x4's. Looking at the specs of the Tapcon screws, I see this:
For 1/4" Tapcon screws in lightweight concrete masonry units (closest thing to cinder block that I can see), the tension is 250 lbs, and shear is 620 lbs.
1. Tension refers to the force needed to pull the screw out of the wall, and shear is the force needed to cut the screw in half, correct?
2. These values are per screw, so that if I use three screws to attach a 2x4 to my wall, it would take 750 lbs of force to pull that 2x4 off the wall, and 1860 lbs to shear the screws in half. Is that right?
Re: Holding power of Tapcons
Jason Roehl in Lafayette, IN
>In theory. In practice, I've often had a hard time getting Tapcons to bite into CMUs. Concrete? No problem. For "cinder blocks", I go with mollies.
Like one of our members used in his sig line a while back, "In theory, theory and practice are the same. In practice, they're not."
Jason
Dick Coers
>In this case I would say shear would be any force that tries to slide the 2x4 across the face of the wall. Either down or sideways. If you are concerned, add some liquid nails under the 2x4. Then it will take a bunch of load!!!!! I prefer the hex drive tapcons for the more positive drive. I start with a counterbore in the 2x4 so the hex will be below the surface if you need that application. It's just too easy to ratchet out of the phillips heads.
And that does not account for rust.
Stephen Roth
>I have used those in cinder block walls. Although the walls were admittedly "leaky," I was suprised that some of the tapcons actually rusted all the way through and what remained was essentially just a rusty nail stuck in a too-large hole. After about 5 years, I could pull them out with my hand. Just a warning.
Re: Holding power of Tapcons *LINK*
Lee Schierer - McKean, PA
>I think your strength values may be a bit low. According to the Tapcon site (see link below) a 1/4" fastener has a pullout of 490-800 pounds in hollow block depending on the length of screw used and a shear value of 1059. Two of them would be stronger than the 2 X 4 you are anchoring to the wall. Consider putting a hard washer under the heads to prevent pull through. Installing them with a hammer drill makes them bit better and gets them torqued down tight. Use a six sided socket for driving or have lots of 12 point sockets handy if you plan to drive in very many. DAMHIKT.
Lee
Tapcon Strength Values
Brent in Montreal
>I've had the same experience Jason has. Cinder blacks just don't give much in the way of holding power for Tapcons.
Construction adhesives
Galen V
Pete LaBelle
>If one screw holds 250 pounds, yes, in theory, 3 would hold 750 pounds. But, take into consideration this:
1) That is assuming you have a direct pull on each of the 3 screws. If the pull on any or all of them is at an angle other than a direct pull, strength will be compromised. Also, if your board loses grip on on the top fastener & starts to peel away, mechanical leverage starts to work against you on the remaining fasteners.
2) Adhesives are great in shear (bypass failure) conditions, but not tensile (direct pull-apart). Adhesives are also only as good as the cleanliness of the contact surface. Dirty/dusty/painted surfaces yield poor bonds.
3) On load bearing wood attached to concrete, I favor thru attachments where possible.
Good luck !
