>I would love to know where I can browse/buy plans for fireplace mantles. I have searched the web and can only find books on mantles and about 2 individiual plans. Or would the suggestion be to find a mantle that I like and just attempt to replicate. DH has made things for me before but from plans, I'm a visual person and need to see the plans or at least a sketch before I say "make this and here's how". Thanks much!
>Just a thought . . . after Ol' Norm went mantle hunting on TOH I've noticed a lot of them surfacing in shops. Even for here (west Texas) there are quite a few stacked against walls behind other stuff or brought out to the front of the stack-o-stuff. Most shops have no beef with you measuring things so you can go home to "make sure it'll fit before you buy ". Like you said, at least you'd get the education on styles.
>Most of the books that I've seen have several different styles included. (I have 2 of them, but they're at home and I can't remember the titles off hand.) Most mantles are basically variations of the same theme. I would recommend getting a book which will explain construction, mounting, etc., and if you don't see one you like in the book, it would be easy to modify the decorative elements to your satisfaction. Also, I've searched under google images before for different pictures - you'll find dozens of different mantle styles there.
>When I built a fireplace surround for a neighbor, I got ideas by looking through the websites of companies that supply pre-made versions. Tweaking their design a little was simple enough, and thinking through the problem of how to make the pieces and assemble them was just a mental exercise. Not too hard to do. Mine came out similar to this...
>I firmly believe that any competent woodworker and most serious carpenters could easily scale and build you a mantle just from a photo. There is very little mystery to it. If you want to get fancy with arches and inset veneer panels and carvings and fluting, you will need someone with those skills, but the dimensions and other information you get from plans are neither here nor there. They should be scaled to suit the room and the fireplace opening -- there is no right or wrong to the dimensions. If you are a visual person, you can tell from an elevation drawing whether the scale and detailing of a particular design are to your liking.
I googled "fireplace mantels" and got lots of websites that sell and/or build mantels. I suggest you find a design that suits and get some prices from competent woodworkers in your area. Insist on "shop drawings" and finish samples before you commit to the project.
