ripping 2x3's
ripping 2x3's
ripping 2x3's
Vince F
>I have to rip some 18" pieces of 2x3 on the 3" side. Have a 10" rad arm. Would it be better to cut the 3" off with more than one pass? I mostly cut 3/4" panels, Many years ago.
VF
Re: ripping 2x3's
Are you trying to make the 2 x 3s into 1 x 3s?
>Personally, I'd go to a lumber yard that carried trim.
Other than that, I'd rip it with one pass - but I'd be using a tablesaw :).
Re: ripping 2x3's
Scary...
doug f, san clemente, ca
>Vince - Ripping with a Radial arm saw, to me, has always been an accident waiting to happen. Do you have access to a bandsaw? It would make the operation much safer and just as accurate.
Just my opinion, but I would reserve the RAS for what it does best - crosscutting, dadoes, etc.
BYW, welcome to the Board. You'll find an unbelievable wealth of knowledge here and some darn friendly folks as well.
Doug
Re: ripping 2x3's
Re: ripping 2x3's
Marv....... Northern California Lake Co.
>Hi Vince,
If you were ripping a long 2x3 it wouldn't be quite so bad, but ripping an 18" stick is just too dangerous on a RAS. Even ripping a long board scares the B-jesus out of me. I still have all my nose pickers so I use my RAS for mainly crosscutting and as a work surface. The suggestion to do the ripping on a bandsaw is really the way to go. That's even a lot safer than a tablesaw. I don't like ripping short stuff on the tablesaw either. I've done a lot of it, but I sure don't like it.
Marv
Re: ripping 2x3's
Re: Are you trying to make the 2 x 3s into 1 x 3s?
Vince F
>I need to make 1 pc,1-3/8 x 2-1/4, 14"L, and 2pc, 1-3/4 x
2-1/4, 18" L, then cut rolls and V's in the front surface.
I thought about having them cut, and then thought of getting a small band saw, but I am SO filled up here, I'd have to move things just to move around, I am Stuffed to the gills.
VF
Re: ripping 2x3's
Cut them by hand
Pat Evans
>For no more pieces than what you want, you could do that with a hand saw.
Re: ripping 2x3's
Re: Scary...
Vince F
>thanks for the warning.
Re: ripping 2x3's
Re: ripping 2x3's
>Vince,
Have you thought of just ripping the pieces with a handsaw?
Marv
Re: ripping 2x3's
Re: ripping 2x3's
Vince F
>I've always been extra careful, and dug up the basement floor because my head would bump the floor joists, and banging into one wouldn't be very good, if something kicked back or out. I used to wear a sweat band when I was sweating too much, since sweat in the eyes isn't good either.
I made a tall fence for when I try to rip them. You guys have me thinking about it now. That's why I came looking for a forum, since I forget a lot and didn't do some things, and have limitations, so taking it slower than slow, and trying to avoid Any disasters. Even ran a magnet over the table top to be Sure there were no screws or metal, even though I couldn't see any, but I had a lot of stuff sitting on it.
VF
Re: ripping 2x3's
Re: ripping 2x3's
Fred Davis
>The ten inch RAS is to light of a machine for that big of a bite, even if you have a dedicated rip blade which I doubt.
If you ever ripped stock with a 20 inch Dewalt or Delta, you would immediately appreciate the difference.
Ask a friend with a table saw, try the high school wood shop if they still have one , use a handsaw as some suggested, but the stock you are talking about won't let you stay away from the saw far enough , so save your fingers and rethink it.
FredD
Re: ripping 2x3's
Vince F
>these are OLD pieces, I don't think would be sold. There are lots of crazy shapes That just need paint stripped off them, like a strip of 1" pyramids across the top of the windows and door.
I do things a lot of neighbors wouldn't even think of, and get lots of comments, that make it even harder to work outside, especially with my linits, and cold, heat, and the sun are others. One guy thought I should use a 1x3 for the door stop, when he saw the new moulding. Said he's going to use a 1x6.
I try to do as much on my cars as I can. Was chaning the oil on a new one, and a retired machinist said, Working on it already... Told him, I know it gets done, And the way I want, flushing out the dirty oil. Then he tells me about one time they Didn't even fill his New car with oil when he went to take it, or them putting reg instead of the synthetic he wanted and paid for. When I had a carb apart to check the float setting, he asked if I knew what I was doing. told him I would figure it out. I had a shop manual, so had help.
Re: ripping 2x3's
Re: ripping 2x3's
Vince F
>My fingers Weren't going to be anywhere near the blade. A push stick and other wood to guide it was the plan. Early on in woodworking, I cut my thumb real good, into the end of it with a knife, because I was thinking about something that had irritated me, so try to make sure I pay attention to what I am doing. Being away from it for so long, and my limitations, I am trying to be extra extra careful, and why I came here. I was trying to think of someone I knew who did any woordorking, and only knew one guy real well, and he has passed on.
Re: ripping 2x3's
Re: ripping 2x3's
>I usually use a set of four spring holddowns for such things but that big of bite on that short of wood scares me. If I HAD to do that on my radial arm saw, I think I would build a sturdy fence fixture fastened firmly to the table, sort of like a tunnel just the size for the pieces to be pushed through. Better would be to take them to someone who has better equipment and pay them to do the cuts.
A far, far safer way would be to cut them on a band saw. I've resawed 12" thick douglas fir 2-bys with my little 14" Delta with riser. There is no chance of a kickback on a bandsaw and you can get pretty smooth cuts with a good blade and a good fence. If you don't have a bandsaw, ask at a local woodworking store and they might know someone.
Re: ripping 2x3's
Re: ripping 2x3's
Winnemucca Lynn
>Vince, Some years ago, I was ripping some lumber with a radial arm saw. The instructions that came with it showed me how it was done. I had taken some shop at the local community college and am/was very safety conscious. As a result, I was standing out of any line of fire. The saw grabbed the lumber and shot it across the room and right through several storm windows I had stored. I turned off my saw and only use it now for cross cutting. My recommendation is to find another way.
Lynn
Re: ripping 2x3's
Re: ripping 2x3's
Vince F
>Years ago I bought a flintlock, muzzle loading rifle. I wanted to test fire it, and went down the basement. I wasn't going to shoot the lead balls, and instead of the cloth, grease patches to seal the ball to the barrel, I had the double cupped end plastic alternatives. I didn't have the measuring cup for the powder, but they were about the size of plastic stoppers for wine or champaign bottles. I wore saftey glasses, squatted behind a piece of 3/4" ply, and shot into a thick slab of styrofoam 20' away. I pictured the plug bouncing around, and hitting me in the back of the head.
I went light with the black powder, and got a woosh sound when I fired it, which got louder as I increased the charge. When I got it to crackle like a gun shot, I stopped. Then I started to notice the rotten egg, sulfur smell of the powder.((
Realizing that I only have to cut off 1/8" of the wide side on one of the pieces, and 1/4" off the narrow side of 2 pc. It is probably my limitations, but it gets really confusing, and I have to write and rewrite down things to try to understand or remember. It's like I have to measure over and over, not just twice before cutting, but it doesn't help that the 3 pieces of trim are 3 different lengths, and 2 similar ones are 1/4" diff in length. Those 2 fit locations that are 1/8" different in width, but being exterior trim against bricks, caulking will compensate for the width.
Re: ripping 2x3's
Re: Cut them by hand
Vince F
>don't know how good I am at cutting wood with a saw, especially narrow pieces.
I just changed the exhaust on my 86' Chevy, and to try to reinforce the spot where the pipe is welded to the flange, where the pipe is bigger, which always fails first, I had a sleeve that was split, that fit inside the pipe with a lot of effort. It stuck out 1/2", and didn't fit into the smaller dia. of the converter, which I didn't find out till I took off the old pipe, so had to cut it off. The sleeve was 2 1/2' dia 1/8" thick wall, and took me about an hr to cut it off, resting every 5 min. Thought about taking it to a machine shop, but it was late and at a friends garage.
Re: ripping 2x3's
Re: ripping 2x3's
>Vince, I'm with Lynn on this. I have a 10" Radial Saw I bought when I was about 17, and I am 59 now. I like it, but I never use it for ripping. I did, but not any more. When I had no other tools and the fearless attitude of a teenager I tried to rip a 3/4" square stick into two little stop strips. I pushed it through from one end and then reached around to pull it out the other. The saw grabbed it and shot it like an arrow right through a gallon can of lacquer thinner and smashed the stick against a cinder block wall. Did not even turn the can over, just right through it. This was after I cut the end of my thumb nearly off with it. My strong advice is don't try ripping.
If you need to make a 2x3 thinner I would raise the blade and nibble the stock away. In other words, if you want the wood to be an inch thick, raise the blade an inch off the table and then just start at one end and take many many passes with the saw as if you were making a cross cut or dado. You could do an 18" piece in a matter of minutes. It would leave a rough surface, but if that side is not exposed it would not matter, but if it did show you could smooth it with a plane or a scraper, or even sandpaper.
Re: ripping 2x3's
I agree
Bill Tindall, E.TN
>Unless you are experienced in ripping on a radial arm saw, find another way. I regard ripping on a radial arm saw one of the most risky procedures in woodworking. I agree with the band saw being the safest approach or find a friend with a table saw.
I rarely see anyone using a radial arm saw now days. They are good for rough cross cuts, but this operation is not a big part of typical woodworking. A table saw with sled will handle most jobs a radial arm saw is useful for , and do it more accurately.
Re: ripping 2x3's
Re: ripping 2x3's
>Vince,
When you are all done sawing those three pieces on your RAS, please come back and let us know what it's like to have fewer fingers. I hear that people who have body parts missing, still have the sensation that the parts are still there. I think they call them "phantom" parts.
I'm getting the sense that no matter what we suggest and advise you to not do, you are going to go ahead and cut those 2x3,s on your RAS anyway.
One more suggestion....sell that RAS and replace it with a bandsaw. Do it today! Even using a RAS for crosscutting can be scary and dangerous.
Marv
Re: ripping 2x3's
Re: I agree
Vince F
>I've done a lot of ripping with a RAS, but mostly panels. I had put hinged extensions on the top, to support larger panels. Most of the things I used to build, I hand veneered, or upholstered.
Re: ripping 2x3's
Re: ripping 2x3's
Vince F
>I'm tempted to buy a band saw, but may never use it again. I had a friend who had a cabinet shop, but he went under.
Re: ripping 2x3's
Re: ripping 2x3's
Fred Davis
>Lynn, that is a classic example of riping from the wrong side of the blade. Thats why a RAS should only be used for cross cutting with a zero or negative hook blade.
Glad you surrived in one piece ;-))
FredD
Re: ripping 2x3's
Re: ripping 2x3's
Fred Davis
>Marv,
you said what I was thinking, so not to put to fine of a point on it, I think from reading Vince's posts , any day he spends in his basement could very well qualify for a appearance on American Funniest Home Videos.
Actually not very funny at all considering how long it takes to grow a finger...
FredD
Re: ripping 2x3's
Re: ripping 2x3's
Vince F
>I've been told I may someday get a Darwin Award, because I don't worry about dry rot on the outside of tires, but never had a tire fail. I'm still going strong except for toxic fumes that got into an office, and now I do things with physical limitations, so have to change my style a bit, like lashing myself to a 24' ladder to point the bricks up near the roof of my 2 story house. Put cans over 3/4" pipes sticking up out the concrete to hold a wire fence, so i wouldn't get impailed if I fell. Thought about 3' think styrofoam on the concrete, but didn't think that would hurt me. Hard to keep my balance in the wind, with both hands doing the troweling. Thought about a great uncle who fell off a ladder when he was 93.
Got out my saftey glases and face sheild, but the glases don't magnify, and the headband broke off the shield. Made a new push stick because I couldn't find my old one. Coated the notch with rubber cement, so it will grip wood better. Cut the notch on an angle, for holding it where I will stand.
Re: ripping 2x3's
Re: ripping 2x3's
>>...I'm tempted to buy a band saw
If you do any kind of working with wood, a band saw can be one of the most useful tools in your shop. You can safely cut pieces smaller than safe to cut any other way. You can get very smooth cuts on thick stock. You can resaw wider boards into smaller boards, cut circles and curves, cut complicated angles, etc. And a bandsaw is never far from a woodturner.
