Getting back to working wood
Vince f
>after many years and a disabling injury. Trying to get back up to speed, and not injur myself, and figure joining a forum would help me get back faster, or learn some new tricks.
Vince F
Re: Getting back to working wood
Vince F
>OK, now that I see I could post, I'll give more info.
I used to do a lot of woorworking 20yrs ago, and then had a chemical exposure injury in an office of all places, that really messed me up. Gave me some brain damage and nothing else works as well as 30sec before the incident, so everything is much harder for me to do, adding to I am 20yrs older.
I am restoring and remaking old trim pieces on the outside of the windows and door of a 100yr old row house. I thought about buying a band saw, but was able to patch all but 3 pieces, and I Don't have the room for one, since I have collected materials and things to use or for planned work, and don't get much done. I started the repairs to the woodwork 10 yrs or more ago, and didn't get very far.
I have a 10" radial arm saw and many power hand tools, and figure I can cut the flat, curved shapes with them with a little inginuity. I don't get much done before I fatigue, or mentally I can't continue.
I had to clear off the saw table, and move stuff stacked around it, and then I started sorting tools, screws, and nails. Then had to lube the saw, that was really hard to work the adjustments, now I am trying to remember and relearn how to make cuts Have to be extra careful because I still have stuff on the floor around the saw, with 2'wide to walk around the front.
I'm trying to cut the trim pieces out of 2X3' lumber, since that is the closest size, though one door trim piece is 2 3/4" wide, so just going to add some 1/4" stock to it. I am not that worried about being that perfect, just want it to look decent. Most people have the trim covered with aluminum or vinyl. One neighbor asked me if the other houses had the fancy trim. They all did, but few are showing or left. One new neighbor had his replacement windows replaced.
My front door is pretty nice with 3 beveled, arched, pressed glass panels. I had wanted to build a new one and insulate it, and change the 2 raised wood panels below the glass to 3, matching the glass ones in width, which there are 2 widths. I used to build complicated folded corner horn bass speaker cabinets, but my brain damage has made it hard to visualize in 3D, and my memory problems make it hard to remember what I just drew when sketching out a design or detail, so I am redoing the sketsh over and over and over.
The door has some rot and is coming apart, and right now I Just want to patch and rebuild it to make it last, and maybe at a later date I'll try to build a new one. Probably uninsulated, since that Really got complicated with rased glass and wood panels.
I used to hand veneer many things I built, and have about 2K sq ft of veneer, mostly teak. I started working wood, building a sofa, chair, and many tables, living in a garden apt, with NO tools. I saw a design I liked that was simple with the sides of the tables upholstered like the sofa. The Sofa I had seen in a mag, cost 2K in 70' and was in NYC. I built everything, even a custom table for my stereo components for 135$. Only thing I couldn't find was veneer, though I didn't know about veneered ply back them so filled, sanded, stained and finished flakeboard till I found veneer. I had a lumber yard cut all the wood, and I was too cheap to buy a drill, just being lair off from work, so bought a pin holder that has a chuck with a handle, and hand drilled the holes.
I wanted a wood parsons table, and couldn't find any, even in a block long furniture store, They had formila ones that they sat phones on to call a salesman to where you were, but didn't sell them. By that time I was in a house with a basement and had some power tools, so made a teak veneer one.
Well, that's Part of my story.))
Vince F
>good Afternoon Vince,
You'll find that trees still grow after a long absence. I hope your future is bright and getting back is less daunting than you imagine. Good luck.
George
Vince F
>Thanks George.
Not that easy when everything is a struggle, and hard to stay motivated. I used to handle 4x8'x3/4" sheets of ply and flake like nothing. I have some balance, coordination, and strength problems, so pretty dinged up. Scared myself when I pulled the saw back onto a piece of 2X to test cut, that I had moved, after shutting the motor, and stopped the saw with the blade with a bang.
I didn't remember if teh saw was set for 110 or 220V, and had to check. Couldn't get the screws out on a plate where the switch is, that turned out to be the wrong one. Got it switched back to 110, but Had to vac out the inside of the motor housing. I love restoring old things, but I Clean things before I throw them out.((( My problem is, that I Still plan to do things I used to, and buy parts and materials, but then they just sit. Easy to plan and buy, but hard to do. I bought a new car, and have Many things to add or change on it, and a yr later only have a few done.
Well, hopefully I will relearn things or get more motivated from the forum.
VF
Dis be da place !
steve mackay
Welcome Vince!
Stuart Hough
>We are all here to help. Just ask, and you shall receive many times over!
