PC 390 K Random Orbital Sander - some thoughts
>I had been impressed when I saw it at the IWF. The article in Wood was fairly accurate - it is a really nice sander.
Start up - you know how ROSs sometimes "jerk" when you turn them on? This one has a smooth start-up. You could even start it up while resting the sandpaper on the piece if you were so inclined.
It does not go on forever when you turn it off. If you have a sander sitter, it won't clean off the bottom very well :). Seriously, I can turn it off and set it down and it will be off by the time I set it down.
Speed - the speed settings are 1-6. I was cruising along on 1 for some fairly smooth walnut and it was doing fine. I turned it up to 2.5 for some red oak and it did a real nice job on it. I haven't had it over 3, and I don't know if I really need to.
Power - plenty of power. It did not really bog down with any comfortable amount of downwards pressure.
Handling - I have relatively large hands. I could grip it reasonably well. If you have small hands - it may be somewhat of a stretch. It does not have much of a taper or "neck" beneath the portion where you set your hand. The "top" of the ROS is ~3.5" wide x 5.5" long. So - to repeat, if your hands are on the small side - this may be somewhat uncomfortable for you to use for a protracted period. The lower center of gravity and lower height of the tool make it easier to handle for me.
Dust collection - I was fairly impressed. It collected all of the fine sanding dust quite nicely. Removing the dust collector was a bit of a problem as it is new and somewhat stiff.
I tried out the Festool sanders at the IWF as well as the PC 390 K, a Bosch and Dewalt. At ~$130, the PC 390K is not inexpensive - it is cheaper than the Festool 5" at $165 or a Bosch. Is it worth it? Time will tell. It handles better than any other ROS I've had or used extensively. My old Dewalt is now going to be retired to a back-up and my old Sears is going to the Humane Society thrift shop.
