Re: sp3
Curly Smith
>Sorry, I misread your original note.
To determine is SP3 is installed, go to Control Panel | Add or Remove Programs, and scroll down to the bottom. If SP3 is installed you'll see a notation for "Windows XP Service Pack 3".
If it's not installed then you should install it. Back-up any critical data first on the off chance that you're in the 0.001% that will have problems. However, if you really don't want to install it, then there are a few other options:
Uninstall the Google or Yahoo toolbar if they're installed. If that doesn't work try uninstalling all other add-ons or Browser Helper Objects (BHOs). Reinstall 1 at a time to isolate the culprit.
If it's a recent change (i.e. everything used to be OK but now it's not on multiple web sites) then go to Control Panel | Add or Remove Programs, click the "Show Updates" box at the top and scroll down to the bottom. You'll find the updates to Windows Internet Explorer and Windows XP listed with an "Installed On" date. If one matches the date when your problems started then remove it and see if the problem goes away. If that resolves your problem then you'll need to visit the Windows Update site and block the particular update or it will just re-install if you're using automatic updates (note: if you're using auto updates then you should have SP3).
If you don't see any updates to IE, go to the Windows Update website and get the updates.
Or, if you're simply tired of all the IE problems then you can switch to Firefox, or one of the other browsers, for the vast majority of your internet use. You download it here: Firefox 3. Firefox will co-exist with IE, just make it your default browser and only use IE when necessary.
