REAL MILK PAINT
OT-Rustproofing/underbody sealers
Andy Lincoln,in Dearborn,MI
>Hi All,
I haven't sat to research the net yet,we all know the wisest collection of infromation is here at WoodCentral.I have been able to fall into a deal on a new to me,2000 Chevy Silverado LS extended cab pickup truck(wood and tool hauler).This truck is unbelievably clean ,the 87-year old former owner stored the truck here in the harsh Michigan winter in his garage while he stayed warm in the southern states. My new truck has never seen snow!!!Anyhow with the frame/underbody/engine comp.etc looking almost showroom new,the truck has 33k miles on it,are there any products/treatments/maintenance that are worth investing in to help keep this truck looking as good as possible.I do not have the ability to park in a garage,and most likely my truck will see snow,road salt and other harsh winter elements : (Any help would be greatly appreciated.The former owner hasn't stopped driving and just purchased a brand new 2008 Silverado to keep in his garage.Hopefully in 8 years or so he might be ready to sell that one ;)
thanks,
Andy
Re: OT-Rustproofing/underbody sealers
Kneale Brownson dreaming of snow in N. MI
>You can get rattlecan versions of the gravelguard that used to be popular on sheetmetal fenders before everybody started using plastic in the car bodies. I've used it on the doorsill areas and behind wheelwells, as well as to treat a fuel tank before installing it in place of the original that rusted through. It's something you'd want to reapply every year or two to the spots that get banged up by gravel and the slightly finer stuff used as winter sanding.
Don't waste your money
>In an earlier life I had a customer who supplied paints to GM, and they had a test facility equipped like GM's paint line. First was a full body immersion tank filled with primer and anti-corrosion solution. That prepped the body and chassis for the paint finish and was more than equivalent to any after market undercoat, as it did the same thing and got into all the nooks and crannies.
Clint
Re: Don't waste your money-agree
M. McNamee
>I have a 99 Silverado and live on the north side of Detroit. Never in the garage and driven every winter. At 10 years and 166k miles it is just starting to rust at one location on the rear wheel well opening. One suggestion, these models were recalled for corrosion of the front antilock wheel sensors. See if he had it done, if not, I think he can still get them replaced and the computer reflashed under the recall. Actually, it is pretty important to get this done. When the sensors start to give false signals you cannot stop the vehicle at low speeds. I almost took out one of those ice machines you see outside the party stores when mine went bad.
Cold parking is better=less rust
Tom Dunlap
>Having lived in Minneapolis for most of my life I've seen lots of rusty fenders from salt damage.
Vehicles are being built better from the factory and coatings are better as the above reply notes.
The worst temps for rust/corrosion is within about +/- ten degrees of freezing. That's where the calcium or sodium chloride reacts the best. Storing a car in the cold rather than a garage in those temps may be better. My Dad taught me that a garage would gain you about 5-10 degrees overnight. Having indoor/outdoor thermometers showed that Dad was right, again :)
During the heavy road salt weather a quick trip through the undercarriage drive through car wash would reduce the residue.
A bigger concern in the salt belt is the effect of the calcium chloride mist that is generated from the roads. Ask any mechanic about how it is effecting wiring connections. Way worse than the old sodium chloride. The corrosion in the terminals is really hard to track down, clean and regrease. Intermittent faults in the wiring can be dangerous and very frustrating.
I agree too...
John in New Mexico
>When I was a kid in Maine, my parents had two vehicles that were rustproofed. If there was any benefit it was negligible. I had an older vehicle that had less rust than either - it had been driven less.
So minimize your winter driving, wash the underside if you can (do they salt the roads there? Sure did in Maine in the 1980's, salt is the car killer). All the underbody paint and other coatings in the world won't stand up to little rocks chipping it, then salt and water getting in, re-freezing in a seam and pushing the coating apart so more salt and water can get in. Buy the truck, drive it, enjoy it, but don't waste any money trying to preserve it if you have to drive in the winter.
Do they salt the roade here?
Dan Donaldson
>Are you kidding? ;-) They salt the roads here so much that even plastic rusts. We get 1" of snow and 2" of salt, except of course when it really snows, then we get no salt.
(I live about 10 miles or so from Andy)
