OT - FireFox Glitch?
>Running FF-3 which seems fine except for its propensity to "forget" all of my bookmarks and history. Doing a restart of the whole machine brings them back.
Anybody know why this?
mm
mm
Re: OT - FireFox Glitch?
gil jones...lake seminole GA
>Mark,
My Firefox 3.0.1 has lately been needing two attempts to find a site. Also, sometimes after I have shut FF off, and then turn it back on, it pops up a dialog box telling me FF is already on so do I want to shut it off and then back on. Geesh. So far it has not lost my bookmarks. I do make a backup copy of my bookmarks every so often, just in case they all happen to disappear.
Gil
>>... a dialog box telling me FF is already on ...
To prevent further problems, after shutting down all copies of FireFox you might check the the Processes under Taskmanager for persistent instances of "firefox.exe" and end them manually. (This is also a good thing to check when any program misbehaves.) If you find some, be sure to report it as a bug.
JKJ, beta tester for Autodesk in previous life
Curly Smith
>It's a known, but infrequent, issue. You might try the following fix from Mozilla:
Bookmarks disappear after reopening firefox without a restart which suggests that the localstore.rdf file is corrupt and provides a link for fixing it.
Thanks, Curly
>A bit complicatated but I'll tackle it.
[A bit later |;-}} ]
Howard Acheson
FireFox is designed to close down gracefully saving some info. It takes a while to do this even though the window closes immediately. It's still closing down in the background. If you attempt to re-start it right after closing it down, you will get that message. By the time you read the message and close it, FF will close down and you can start it right up.
As to the OP's original question, that is probably related to his setup. It does not happen on my three machines or others I know of. So far, FF3 has be pretty stable for me.
