Have a question? Ask Woody!
OT-concrete tack strip for carpet
Steve Silca
>I have been having a heck of a time trying to put tack strip down in my basement for some carpeting. The nails bend over on the bottom of the strip, or the hole blows out all together. I have tried to predrill and use other masonry nails, but even this does not seem to be working. What are your thoughts?
I have heard that simply cleaning the floor well and using liquid nails may be the answer.
Also, should I use them double wide?
Re: OT-concrete tack strip for carpet
Kneale Brownson dreaming of snow in N. MI
>Carpet layers who have worked for me on slab buildings have used both the pound-in cement nail strips and the kind where you drill and insert an anchoring fastener. The latter were more stable in the long run. The fastest install on a slab I watched was a guy using a Bosch drill designed specifically for that task. He used a fastener that went into a hole drilled through the tackstrip and into the cement in one step. I think he had to hit the fastener once or twice to complete the process. I'd talk to a carpeting supplier about techniques.
Allan A Campbell
>That's one of those things I simply can't figure out. I have watched pros do it and they just hammer the concrete nails in -- and they hold.
I do what I think is exactly the same thing and they either bend or blow out.
Last time I used the shortest tapcons I could find. Slower than the pros, but lots faster than me using nails, and a lot less frustrating.
I wish I knew what I do wrong.
Lee Schierer - McKean, PA
>If you are tapping in the concrete nails with a regular hammer then you will have a problem. As I understand it you have to use a heavy hammer and as few hard blows as possible to drive the nail. Have you considered using a powder actuated power driver to nail down your strips.
Lee
Steve Silca
>I have a Remington which uses .22 loads to fire a nail. The problem there is that the nail usually remains about 1/4" proud of the surface, so it would be in the way of the carpet.
Is this what you're refering to?
I suppose I could try to use my mini sledge and do it in one powerful blow...
Oh, you gotta be soooo fast........
>Like so many things you've got to have the knack. Drywall mudding is one of them. Carpet laying is another.
Sure I can do a great drywall job. Sure I can lay carpet well. But it takes me 5-10 times as long as a pro.
THe trick to those carpet nail strips is speed. Ever wonder how a pneumatic nailer can drive such a long skinny nail into wood withit it bending. It's a straight and FAST blow. Same thing with those concrete tacks. You've got to hit it really hard and drive it with great speed.
Well that's what I've been told by guys that do this for a living.
I, on the otherhand, found that this technique mearly IMPROVES my ability, but I still can get only about 50% on them in, compared to the 10% before I learned this trick.
A heavier hammer and and really fast blow aren't enough, as I found. You need accuracy. Otherwise you'll discover how fragile the little wood strip is that holds those nails together.
Oh, and just to make you laugh.... make sure you know which way is up.
The thicker nails go down, and the skinny angled nails go up ;)
Happy Woodworking!
Phil Joines Krum, Tx
>You probably need a 1 step hotter load.
