45 deg, zero clearance TS insert
Dan Mitchell
>Is there a way to make a 45 degree, zero clearance table saw insert? I've made dado ones, & I have a 90 deg zero clearance, but I'm wondering how you'd precisely cut the angled slot for the blade in a 45 deg insert. Obviously, you can't just raise the blade into the insert like you would for a 90 deg type. Depending on the saw, putting it in place may be tricky was well. Has anyone ever made one of these?
Dan
