200+ woodworking book reviews
Dewalt 788 Scroll Saw blades
jason
>Bought a used (new, really) DW788 last night for a great price, but unfortunately, I think I may have bought the wrong blades. The guy I got it from had used a pin-end blade so I got more of those, but the pic on Amazon shows the blades for the DW 788 as smooth-end. The tool didn't come with a manual so I'm asking here. Anyone have one of these?
Also, I had to go to no fewer than five stores to find the blades, and one tool specialty store had never even heard of a scroll saw. Either employee. Sheesh, Amazon can't kill places like this fast enough.
Re: Dewalt 788 Scroll Saw blades
Yup....
>I had a bunch of pin end blades left over from my older scroll saw when I purchased my DW788. It's easy enough to break of the pins though and they'll work fine of the DW788.
IF you want to get really good blades, try Olsen blades. They'[ve got some that look like stainless steel (shiny) and they're a bit more xpesnive but the cut better in hardwoods. For softwoods or rough cutting just about any blade will do.
They make these spiral blades.... think barbed wired... that are basically a thin blade that has been twisted so it has the ability to cut multi-directional... but I hate them... I call then squirrelly blades because they can't keep a straight line.
Happy Woodworking!
BobP
>The 788 and most newer scroll saws of the type do NOT use pin-end blades. Pin-end blades are used mostly with hand powered coping saws.
You should be able to find pinless blades at places like Rockler, Amazon, etc.
BobP
Re: Yup....
jason
>Hi Mark,
so would I just pop the pins off, cut the pin ends, or something other?
I only spent $8 on three packs of blades, it was more the 40 miles driven that makes me crazy. Guess I can take them back and get the proper ones.
Jason
Re: Yup....
BobP
>Jason,
On some types of pin-end blades the pin is sorta loose and if you position the blade over a small hole in a block of hardwood you may be able to tap the pin out. If you cut the ends off the blade may become too short for your 788 to grip it properly. Also, in my experience the pin-end type blades are usually thicker than the pinless types that you would typically buy for the 788. As Mark mentioned, Olson is a pretty good mfgr of scroll saw blades. If you start looking into it you will find that there is quite a variety of scroll saw blade styles. I think more so than any other type of blade I have run across. I have a DeWalt 788 and love it. Just be careful to not overtighten the blade retaining screw. It might cause the clamp to break (been there, done that).
BobP
mike@American Sycamore
>Olsen has a great web site with a chart that will tell you everything you ever neded to know or wanted to know about scroll saw blades.
Re: Dewalt 788 - Flying Dutchman blades
del schisler
>I second that the Flying Dutchman blades are the best I use them In my Hagner I have tried some other one But the dutchman comes out in frount of the rest del The link is posted So wont do it again
Wait a minute Jim
Dustmaker Mike
>you didn't mention a place to eat near there(-; How goes things?
Jim DeLaney, Austintown, Ohio
Re: Wait a minute Jim
>Well, Mike, I usually order by phone - and there is a phone in the kitchen...
Jim D.
