Bandsaw blade sizes
Bandsaw blade sizes
Bandsaw blade sizes
Dan Mitchell
>I recently got a Grizzly 14" bandsaw, which is spec'd for 106" blades. I was hoping to pick up a couple blades locally today for a project, 1/8" & 3/4". In looking online at Rockler & Woodcraft however (only local sources, so far as I'm aware) the closest they list is 105" blades. Grizzly does list a selection of 106" blades.
Please tell me the length it "nominal", that the 105"-ers will fit, and that I'm not limited to Grizzly/proprietary blades.
Dan
Re: Bandsaw blade sizes
wilbur
>Quick answer: those 105" blades will probably work just fine.
Long answer: There's a formula you can use to calculate the length of the band you need for any bandsaw. Take the blade off and use the tensioner to put the wheel in its lowest position. Measure the distance between the centers of the upper and lower wheels. Now crank the tensioner until the upper wheel is as high as it will go. Measure again.
The length of the blade you need is 2*(distance between centers) + 3.14*(diameter of bandsaw wheel).
Using your two measurements, you'll be able to come up with a upper and lower range of bandsaw blade lengths that will work on your bandsaw, although when I order blades for my bandsaw, I use a length where the upper wheel is slightly below the center of the range.
If you look at the formula, a 1" shorter blade means that the upper bandsaw wheel will sit just 1/2" below where it would for the longer blade. Which is why the 105" blade will probably work.
Dan Mitchell
>Thanks for the reply. I understand your formula, the distance on each side of the wheels & the circumference of one wheel (pi x diameter) to yield the portion of the blade covering 1/2 of each wheel. I'll try that when I have access to the saw. I think you're probably right about the 105 fitting.
Dan
Thomas S Stockton
>Dan,
Look in the yellow pages under saw sharpening or saw blades and find a local shop that will weld them up for you. I mail order mine and am very happy with the supplier linked below, there web site is pretty basic but if you call them they will be very helpful.
No need to buy proprietary blades all bandsaw blades are esentially custom lengths, they come in a long roll and are welded to whatever length is needed, there are just some lengths that are more common so local stores will stock those knowing that they won't sit around for years.
Tom
steve mackay
>Ran into the same thing after Craftsman stoped selling or only had a couple sizes on-hand. I looked at the inards of the saw and measured the travel of the whole blade tensioning rig. Found out I could go almost 3/4" up or down in size. Mine's a small saw so I'd imagine you've got even more leeway.
Tom, did you mean to include a link?
Dan Mitchell
>I measured the adjustment range on the Griz, not much, I think for right now I'll order a couple from Grizzly for my project while investigating the options, including getting them made-up. This is the 1st bandsaw I've owned, I just expected the blades would be fairly standardized.
Dan
Re: Tom, did you mean to include a link? *LINK*
wilbur
>Try Suffolk Machinery before you order from Grizzly. They will make any size you want, and their Timberwolf bandsaw blades are just great.
Suffolk Machinery - Timberwolf blades
Thomas S Stockton
>Dan
Somehow it got lost between my entering it and being posted. I use Lenox blades but a lot of people like the Suffolk ones linked lower in the thread. If it doesn't link it is www.hastingssaws.com
Tom
