OT Painting concrete basement walls
Tim Greif - West of Chicago
>LOML wants to paint our unfinished basement walls to brighten things up. They are bare concrete, never painted. We built the house 19 years ago and there have never been any moisture issues. We're on high ground. Don't even use or need a dehumidifier. I powerwashed the walls the year after we built to get rid of the "dusting" that concrete gets.
Two questions. Do I need a special prep for the walls? And what type of paint is recommended. Again, I'm not waterproofing it, just painting. An acid wash seems overkill to me and would be more difficult, but I'll be willing to do whatever is needed.
Re: OT Painting concrete basement walls
Nat Robison
>I'm sure you'll get several different responses but my basement is similar to yours......no water incursion problems although I do run a dehumidifier. I've had good results with regular latex wall paint in semi-gloss..........I'm not crazy about flat paints in general and the higher gloss will reflect some light. If you're just looking to brighten things up, I'd go with a not-too-expensive latex.
George Koch
>Tim, the only question I would have is are the walls poured concrete or concrete block. If poured there could still be some oil residue left on the surface and make sure the form ties are below the face and properly filled or they might bleed through the latex paint. Block walls tend to more porous and need more coats unless you use coating with fillers in it, such as dryloc or thuroseal. Just my opinion. George
Re: I like Dtyloc
Stephen Roth
>I used DryLoc in 3 basements so far. A big advantage for me is that it is so thick that it fills in the holes and makes a more uniform look to the wall. It is a little flat. I have overcoated it with a semi-gloss Benjamin Moore product for walls, which is very nice. Don't even try to clean up the brushes after you use it. It has so much sand and gunk in it you just have to throw everything out.
Also, if you are the first person to paint the walls, be good to them. Usually, the first coat on a surface is the weakest link in the chain for every other coat for the life of the wall.
wilbur
>Even though you haven't had moisture issues, I'd strongly consider using Drylok. My basement didn't have any moisture issues, and I used Drylok to paint the walls white. I found that the humidity in my basement dropped noticeably.
Nat Robison
>I should have mentioned this as well in my above post but I also used Drylok on my basement block walls. I was trying to use it up but found that it did a good job of filling some of the holes in the block since it's so thick. I painted over the Drylok with regular latex wall paint and it looks great.
Jesper, Denmark
Jesper, Denmark
>Even though you don't have water problems, yopu should consider a water vapor permeable paint. There IS some water transfer from the outside to the inside of the concrete. You do not want to trap this under the paint, but to let it evaporate into the space as it does now.
John E in SC
>I don't understand why you would want that. Most of us generally try to keep moisture OUT of our basements (hence the use of dehumidifiers), and products like Drylok prevent water from coming through with no apparent ill-effects.
John
Thanks guys -----
>Looks like I'm gonna follow the general advice to use Drylok. If for no other reason than to fill in all the little blemishes and voids.
Thanks again.
Jesper, Denmark
Jesper, Denmark
>He does not have a moisture problem, so does not need anything to stop water coming through the wall.
Any concrete or block wall is a permeable membrane, so moisture will come through - but not more than it easily evaporates into the room. If you use ordinary paint, the paint film will trap the moisture between the paint and the concrete, possibly causing the paint to peel off. This is a mess and difficult to fix afterwards.
Dehumidification in a Chicago basement is a summer problem, where the hot humid air is cooled in the basement, causing condensation. It is not caused by moisture coming through the wall.
