Workbench top opinions needed
Stuart Hough
>I have a chance to get an old bakers' tabletop for a good price. It is either 1 3/4 or 2 inches thick, 7 feet long, made of maple and showing signs of wear. It will have to be flattened, of course, but I need help in the thinking process. Will that thickness stand up to woodworking without bracing the underside? Thanx in advance for the use of the brain trust.
Re: Workbench top opinions needed
>They sell plenty of tops that thickness at Woodcraft and other places - so obviously they will work :).
You mentioned length - what about width? You might want to consider putting on some skirting of 8/4 or fat 6/4 maple that is ~3" wide. Put this on edge. That way you'll have something more rigid on the edges for drilling dog holes and mounting vises.
My $0.02.
It should be fine
>That's a substantial piece of maple and will hold up well to the types of pounding and work-holding you're likely to subject it to. I like JL's suggestion to add a skirt around it, especially in the front, where you will probably want dog holes. The most important part of the bench, though, will be the understructure, which must be very rigid and resist racking in all directions, particularly lengthwise.
Ellis Walentine, Host
