Heating idea
Mitch from Canada
>Hi everyone,
I built a new garage 2 years ago and unfortunately to wood "bug" bit me AFTER I built it. At least I have 10' 2x6 walls though.
Just looking at heating it...read about the Radient overhead heaters, forced air etc... I had read in a Shop Ideas magazine from FWW about a guy who installed an insulated sub floor over his concrete slab with 2 x 4s as joices and styrofoam sheets between them. Plywood on top. My (one day soon hopefully) wood shop is in an area 18' by 31' that I share with two vehicles. So my actual space with cars inside is about 18' x maybe 14'. Anyway, I was just tossing the idea around of making a subfloor with in floor pipes running between the joices. Heat of course would be supplied by a Water heater in the shop (Gas or Electric)... Now I don't forsee being able to do this in the area where the vehicles sit due to the wieght, but could I run additional water lines along the walls beside the vehicles like a baseboard, to help heat that section of the garage?
Now, the way I see it, the advantage is in floor heat in the main area where I would work with no air movement. Disadvantages could be the 2 inch difference in hieght from the cement pad under the vehicles to the top of the sub floor.
Anyway, it was just something I was wondering about. Any opinions about what you guys use would be helpful. I'm in Saskatoon,Saskatchewan, Canada. Chilly winters etc...
Any help is appreciated.
Thanks.
Mitch
