REAL MILK PAINT
Band Saw Beargings
Band Saw Beargings
Band Saw Beargings
Mike in VA
>I have an old Walker-Turner 14" band saw. The upper wheel bearings have gone bad. I pulled the wheel, to see what size bearings were used, and it looks like they are an odd size. The bore measures 0.590", while the OD is 1.377" (at least that's what my dial calipers say". It's 0.440 thick. I checked McMaster-Carr and Graingers, and neither one have bearings in this size.
Any suggestions as to a source for a replacement?
Thanks.
Re: Band Saw Beargings
Jesper, Denmark
Jesper, Denmark
>Simple multiplication by 25.4 will show you the bearing is 15 x 35 mm, although the width is a little puzzling.
Bearings have been standardized in metric for decades, so nothing unusual about this atall.
wilbur
>Walker-Turner was (in)famous for using oddball size bearings. I have a Walker-Turner 16" bandsaw, and the bearings on the driveshaft have a metric outer diameter, and an English measurement inner diameter.
I think the bearing you need is a 6204 3/4 type, but I could be wrong. I got mine from Accurate Bearing (www.accuratebearing.com). To double check, pull the bearing out, and look on the side for some numbers. There are interchange part numbers available.
Bob Wilkerson - Richmond, VA
>You might want to contact this guy:
Walker Turner Serviced Machinery, LLC
PO Box 666
Coventry, CT 06238
Email: wtsmllc@juno.com
He restores WT machines and sells parts. This was the last email that I found for him. Hope it works...
Bob
Mike in VA
>Thanks for all your help.
Yes, after further checking, the bearing is a 6202 size, metric, and McMaster-Carr has these listed. Hopefully I'll have the old saw up and running in short order.
