How I Make Ebony Plugs
Jim Shaver - Oakville, Ont
>Hi,
I have been asked on a number of occasions how I make the ebony plugs I use in my furniture. I would like to share my process, I hope by doing so I am able to help some of you.
I love making furniture with added details, working with ebony as an accent design opportunity is very exciting to my eye.
This is typical of how I use ebony to accent my work.
I use a dedicated morticer to cut the square for the ebony plug. I use a set of mortice chisels that I have measured with calipers and I use that dimension to cut my ebony stock.
I I begin working the stock by flat with a rasp file, then I use a series of sand papers grits (180-220-320-400-600) to pillow shape the ebony. I use a sponge surface as a base to lay the sand paper on and shape the ebony.
I sand moving the ebony in an oval pattern rotating the stick in my hand being careful to remove each progressive series of scratch patterns and keeping a uniform pillow shape.
After I have the ends sanded to shape and I look to see that there are no deep scratches remaining they look like this.
My next step is to use my Beall buffing wheels to polish the ends, Tripoli and White Diamond only.
Now I need to trim the ends, I use a home made jig and a flush trimming saw. I simply used the same chisel on the morticer to make the cut into the plywood, as deep as I want the plugs thick.
Using the jig I saw half way through on one side, then cut through on the opposite side so it parts in the centre, avoiding any tear out on the edges.
And there you have it, 30 ebony plugs in 3 hours.
I hope that helps,
Take it easy,
Jim
