Re: bubbling of a oak coffe table shelf
Ed Mulligan, Cape Cod
>Charles -
Tap the area with your fingernail. If there is veneer delamination it will sound 'hollow' compared with taps on the surrounding area. Sometimes a delamination will look like there is an bubble of air under the veneer. If it is a delamination, sometimes it can be reattached by applying heat with a dry clothes iron. Put a piece of brown kraft paper on the area and apply the iron. Use a high heat setting. If you leave it on too long the finish will melt so watch out for that. When the area has been warmed up, remove the iron and apply pressure with a small block of wood until the area cools.
If that doesn't work, you will have to slit the veneer, work some glue under the slit, then clamp.
Ed
