>Just pulled up 1200 ft of buried invisible "old fence" using my 800lb Zero mower and "Hanna" softened ground. The petsafe fence folks said the reason I was having trouble with my set up was that the new antenna was interacting with my old buried wire and causing RF problems .... does this sound like BS or real RF situation. The wire had continuity and had a resistance of 12 ohms ( #20 .... 1150 ft long) just like it should according to the accepted specifications.
>Were the 2 wires buried close together. I would not think they would cause any problems unless they are really close, maybe 2 or 3 inches. I'm not an electronics person but have worked with electricity a fair amount. The cable already there won't generate any RF. The one you are using is but it won't travel through the ground very far I don't think. I have one of the fences so I'm interested in what other people have to say about this. I haven't had any problems except where the neighbors dog dug through it trying to get a mole.
In a couple of places both wires crossed, I am puzzled but hope to have the new transmitter back from Petsafe soon to give it another try. They claimed that soldering the wire caused some problems with the RF signal.They recommend just twisting the connections and using a very small wire nut.
>Interesting. I think if it crossed the wire it would only cause a decrease in the RF radiation in just that area. For example when you twist the wire to allow a path of no RF for the dog it doesn't affect the flow in the rest of the wire, it only eliminates the shocking of the dog in that area.
The company I use also recommended twisting the wire instead of soldering. I also covered the wire ends with Heat shrink tubing and silicone rubber.
>If the wires were running long distances in close proximity, you can lose RF signal due to "parasitic inductance" if the conditions are just right, er, wrong. (I suspect this is the reason I read it is considered stealing to get power by stretching a long wire under power transmission lines.)
RF signal loss has been found by some researchers to be associated with the soldering paste sometimes used in soldered connections. However, those tests I've read were concerned with the flux on circuit boards, not twisted wires. Without further reading, I wonder if this is one of those issues which gets repeated "just in case" it may cause a problem. I have a hard time imagining an RF leakage from two soldered wires.
Note that crimping instead of soldering has other benefits and is often required by military specifications: a soldered wire, especially if stranded, can break much more easily when subjected to flexing or vibration.
