insulation
insulation
insulation
Ron
>Daughter lives in old house and the ceiling in the upstairs bedrooms is not insulated. I can get up in the attic an look down in where it should be,the ceiling is at a angle, there is about 6" between the ceiling an the roof. Question is would it be all right to blow in insulation? If not how do i insulate it? Some of the ceiling is flat but about 8' is on the slat.
Re: insulation
Re: insulation
>Blown in insulation should work - provided you have a "stop". You don't want the insulation to interfere with the air circulation up the rafters.
Re: insulation
Re: insulation *LINK*
Kneale Brownson dreaming of snow in N. MI
>You want to assure an air passage under the roof deck from the soffit to the ridge vent. There are foam and cardboard chutes made for installation in the spaces between rafters to make sure there is an air path.
Roof Chutes
Re: insulation
How Old????
>You mentioned the house was old. How Old? What kind of wiring? If it has the old Knob and Tubing wiring (individual strands about ten inches apart) you should not bury them in insulation. They need to radiate off the heat into the air space.
Sheathed cables like Romex can be covered with insulation.
So, look into the cavities and be sure there is no knob and tube. You will need to block off most of one end with card board or wood and provide a baffle or trough to allow for air flow near the roof sheeting and then you can blow it full.
It might be just as easy to put a piece of cardboard in the top side with spacers in it to keep it an inch or so down from the sheeting and then slide in six inch batts. In fact, you might be able to put a rib up the center like a 1 x 2 attached to the sheathing and slide in a temporary piece of cardboard or plastic and then slide in the insulation and pull out he plastic. The rib would hold the insulation down off the sheeting, creating a tunnel for ventilation.
Whatever you do keep in mind the thickness of the sheeting and don't drive nails or staples out through the roofing.
