Pressure rollers question for Performax?
>I have a Performax 16/32 I bought used and have used it for a few years. I just noticed that the infeed and out feed rollers do not apply much or any pressure to the stock. You can easily lift the rollers with a finger tip. They seem to have only their own weight. The question is, should they have more down force? Are they supposed to be spring loaded? What, if anything, should I do?
Re: Pressure rollers question for Performax?
Norman (Ottawa, Ont.)
>Barry,
I have the 16/32 also.
The tension rollers are spring-loaded and there is a procedure to adjust them in the manual.
Not sure if you have the Performax 16/32 Owner's Manual?
In any case, they need to be adjusted and the tension roller pressure can be adjusted by dialing in vertically mounted springs.
I checked the tension on mine, it is more than finger pressure, there is definitely tension there.. More than just the rollers in any case.
Norman
