>Building drawers out of 5/8" thick poplar with 1/2 inch finger joints. The drawers will be 6 1/2 deep, 7" deep and 8" deep, respectively, mounted on 100# sidemounted ballbearing slides. Drawers are approx 18" front to back and 28" wide. The draweres will be faced with 3/4 inch maple, screwed to the drawer fronts. Drawer bottoms will be rabbeted into the poplar. What thickness ply would you use for the drawer bottoms?
>For smaller drawers in use 1/4" plywood without a problem. For large dresser drawers or drawers that will see a lot of weight in them, I have often used 1/2" thick ply.
Of course you could always use solid wood, glued to get the required size, and bevel the edges like the cabinetmakers of old once did.
>I agree with Michael, for drawers in utility use like kitchen cabinets, plycore works fine , for furniture I resemble his remark about cabinetmakers of yore ;-)) didn't realize it showed on cyberspace.
>If the drawers will see a heavy load like tools, coins, rocks, then use 3/8" or even 1/2" plywood.
For clothes, towels, etc you can use 1/4" ply. In an 18 x 28 x 8" drawer you can't put in much weight in clothing of any kind.
When I make my drawers, I put grooves in all four sides and completely capture the plywood bottom. I've never had a drawer bottom fail. If one ever needs replaced you can cut out the back edge and get the old panel out and the new panel in.
>Your question begs another brief design digression... The usual parameters are at work here, primarily function, aesthetics and cost.
In each of these measures, there is no absolute answer; you need to decide what is acceptable vis a vis the customer's expectations.
The cost and aesthetics aren't likely to be an issue here, but functionality is. A drawer bottom has to support, with acceptable deflection, some multiple of the amount of weight you expect to put into it. A drawer bottom for your collection of sash weights will need to be a lot heftier than one for your wife's lingerie. So let the projected end use be your guide. Kitchen drawers that will hold heavy stuff like cast iron frying pans will need to be thicker and stronger than those where you stow your tin foil and garbage bags.
Personally, I would not use 1/4" bottoms, for two reasons: first, they will likely sag over the span of an 18" x 28" drawer even if glued into grooves in the drawer sides; second -- and this is just my personal gripe -- they just feel flimsy, and they sound flimsy when you tap them. 3/8" ply, as Clint suggested, may be perfectly adequate, and it is my choice for most drawer bottoms, but for drawers this size, which may have to handle heavier loads in time (after all, you spec'd your slides at 100#), I'd probably go 1/2". If you use any other kind of man made board, like MCP or MDF, I wouldn't go any less than 1/2".
Agree with the others - it just depends on what you are going to put in the drawers. For light stuff like clothes etc., 1/4 inch should be fine. If you are worried about what might go into the drawers in the future weight-wise, you could always put a center divider in the drawer bottom with grooves along the long edges to capture the plywood and maybe a stub tenon on each end to fit into the drawer front and back. Just a thought.
>Thanks guys. Appreciate your recommendations. If I had the time I would dovetail it, but customer (daughter) says she needs it now before our new adopted grandaughter arrives! Bob
>There are grandchildren involved, so it's half inch cabinet ply. At least with my grandchildren, there is a good chance that at least one of them will be standing in the drawer at some time before they're 8 years old.
Besides, there are always pieces of good quality 1/2" leaning in the sheet goods pile. Often, it's pre-finished stock. Makes life even easier.
