>Hi - I bought this band saw almost 4 years ago and have enjoyed it. It's had only light use. Lately it's started tripping the breaker (it's the only thing on the circuit and that has never been a problem before.) Today I put a new blade on thinking that a dull blade might be contributing to the problem. No change. Breaker is tripped after only a few seconds and there's a hot smell. The bottom of the motor is hot to the touch but not alarmingly so. Doesn't appear to have sawdust in the motor though I haven't taken it apart. The belt tension seem fine. A slipping belt might contribute to the smell but shouldn't cause the breaker to trip (would it?) Before I shell out $200 for a new motor does anyone have a better idea. Thanks in advance.
>there is a switch in the motor that is supposed to kick off after the motor starts. It may be stuck. Take the cover off the bottom of the motor and see if it is stuck. This happened to me once. I cleaned the contactor with sandpaper and it is still working to this day.
>See if the wiring of the motor is correct (there are two halves that are connected in parallel for 110V). If it is, I would think there is internal short.
I agree with Mike that it sounds like the centrifugal switch is not opening up after the motor starts, this will cause the higher current to eventually trip the breaker as well as excess heating.
I have a GO555 that�s about 5 years old or so. The date on the motor nameplate is �2003/3�. You can access this switch for inspection and repair easily, at least on my saw, by removing the three Philips head screws that secure the rear cover on the motor. The flyweights near the switch contacts are thrown out by the centrifugal force as the motor reaches speed, and cause the contacts to open. If you (make sure its unplugged!) slide the plastic collar that is around the motor shaft towards the rear of the motor it will actuate the switch, this entire mechanism needs to be reasonably clean and must be free to move etc.
My guess is that there is accumulated sawdust, or possibly some corrosion that is gumming up the works and keeping the switch closed.
Other possibilities are the starting capacitor, but the easiest thing to check (took me all of a minute to pull the cover off mine) is the centrifugal switch mechanism.
>Thanks guys. Guess tomorrow is motor day. Might as well inasmuch as it's supposed to rain all day. Greatly appreciate the tips and suggestions. Very helpful. Have also talked with one of the tech reps at Grizzly (he actually called me after I sent an email!) Will let you know what I find. Cheers
>on a Delta DC with a "TEFC" motor. There isn't any place to get motor parts around here anymore so I sanded the contacts with 600 and put it back together. How can a motor be "totally enclosed" with the start switch out in the air?
