Poly not drying
Poly not drying
Poly not drying
Gary Evans Tallassee, TN
>Hi all,
I'm taking a stab at refinishing the oak trim on some small restaurant tables for a local pizza place. The trim appears to have originally been finished with the Polyshades or a similar product since the stain does not penetrate the wood at all. I've rounded the edge, sanded the side completely and the top surface slightly so as not to get too close to the formica top and restained with regular old minwax in the yellow can and let it dry for a couple of days.
The coat of oil-based satin poly that I brushed on was still tacky on the underside of the trim after 24 hours. I didn't sand the underside, but I barely sanded the uncut top edge that was left after rounding and that part and the sides have dried like they should.
Any suggestions?
Gary
Re: Poly not drying
Re: Poly not drying
pecker
>Being from a pizza joint, the bottoms may have had some oils or grease on it which may be causing your problem.
