Veritas - Innovation in Tools
OT: Play set bedding recommendations?
Dominic in Buck's County PA
>Hi gang,
Talk to me about play yard bedding. You know, the stuff they put around and under swings sets so it's a soft yielding surface for kids to run and play (and often fall) on.
My daughter got a swing set about two months ago and I just installed a perimeter enclosure. The enclosure allows for a generous clearance around the set and will help to contain the bedding. I was going to get some triple ground mulch. But I thought that there had to be something better out there.
I heard that ground up tires were being used. But I also was informed that this stuff wasn't exactly "kid friendly". I was also told that pea gravel makes a very good play set bedding.
I was wondering if I could get recommendations from those of you who know about this kind of thing.
Thanks,
Dominic
Re: OT: Play set bedding recommendations?
Ken Platt (Granby, CT)
>Since I get to take care of the kids after they fall and hurt themselves, I've learned a thing or two about this.
Of the commonly available and not-too-expensive materials, bark mulch actually works ok, as long as you fluff it up perodically. Pea gravel, however, is better still, and is what I recommend since it doesn't require the (often-neglected) maintenance.
For more info: http://www.playgroundsafety.org/
http://www.cpsc.gov/
http://www.cdc.gov/ncipc/ncipchm.htm
I give a whole lecture on playground safety....trying to put myself out of business so I can devote full time to woodworking.
Ken
(Peds ED doc)
Don't use bark or mulch
Grant in Iowa
>My kids used to go to a daycare where bark was used as a bedding under the playset. They would come home with splinters in their tender hands often. It was usually a tearful process to remove them.
I suggest pea gravel in a good deep layer. Don't buy it in the bags at the homecenter. Instead, buy it from a local sandpit where it will be cheaper. Maybe use a landscaping company to deliver it to you.
FWIW,
Grant in Iowa
Steven Antonucci
Depends on what your playset is sitting on
steve antonucci
>Mine is above my septic field, so I chose to put nothing over it. In the 7 years since building it, only 2 kids have ever had an issue. My niece, who was probably 12 fell off the monkey bars oddly and landed flat on her back. Aside from having the wind knocked out of her, she was find.
My son fell off of one of the platforms earlier this year. He's 2, and aside from being scared, he was fine too. I designed most of the "high places" to be pretty well enclosed to make it pretty hard to fall from a serious height.
I have seen my older kids slam into the twins on the swings not paying attention (on both sides). I think that's probably your biggest danger in my experience. I built a bunch of climbing walls, but I put the easy holds at the top- if you can't get on the wall, you can't climb.
One bit of advice- if you have an open square base, put a sandbox in it! That's the most used feature in the whole playset, and it costs the least...If you need a quick and easy way, send me an email...
Steve
Lee Schierer - McKean, PA
>The nicest looking stuff I've seen used under a playset was the brown mulch made from old tires. It stays fluffed up, doesn't cause splinters and seems to last a long time. To keep the material from getting pushed into the soil they had a heavy woven material under the mulch.
Lee
Re: Depends on what your playset is sitting on
Victor Parisian
>oh and I bet the neighborhood cats love the sand box. :o
Victor - killing time on my lunch break
Steven Antonucci
OT:A solution to cats and squirrrels... *LINK*
steve antonucci
>I am sure this will draw the ire of some animal lovers, but after a summer of chasing squirrels out of the garden, I am contemplating making one of these.
Click the link at your own risk (and don't say I didn't warn you...)
Steve
Last time he sets foot in the garden...
That is so COOL...
Jim in VA
>I need a larger version that can launch Canada Geese out of the yard!
