OT: Lawn reseeding
OT: Lawn reseeding
OT: Lawn reseeding
wilbur
>Tomorrow I'm going to run a core aerator over my lawn, throw a bunch of topsoil and compost all over, and reseed my lawn.
Given how much work I think this will be, I'd like to maximize the chances of the seed taking hold. Is there any downside to seeding at a rate higher than what the bag of seed recommends?
Re: OT: Lawn reseeding
Rob Stokes in North Vancouver
>I dampen the area, then overseed (always), then spread a very thin layer of peat moss (to cover) and dampen again. The peat will hold in the moisture and give you a bit more time between waterings. It also keeps the birds away.
Rob
>As the distance between my eyebrows and pompadour increased, I checked into the reseeding procedure. The aerating and coring sounded bad enough, but the thought of fertilizer and compost convinced me otherwise. I hope it works for you.
Clint
add straw
Bill Tindall, E.TN
>The addition of straw will greatly enhance the germination rate of the seed.
>I agree with the peat moss. (I grow carrots, lettuce, etc that way as well.) I also cover the peat with straw. It must be kept moist (not wet) for the germination process. The combination holds the moisture and the straw shades the seedlings when they are the most fragile. After the seedlings are an inch or so high, I back off on the moisture and water more deeply and less often.
Peat moss is generally acidic so I try to add lime a few months before seeding.
The only downside of overseeding (besides the extra cost) is if you overdo it the seedlings will compete and may crowd each other out. This may not be as much of a problem in the fall as the spring.
Don't know where you are but around here, reseeding is recommended a little later in September when the hot, dry days are tapering off.
Norman (Ottawa, Ont.)
>Looks like we're headed for a dry fall up in my area (Ottawa) with cool temps coming up. At these temps, I doubt seed will germinate and take hold in time..
Yhis gives me an opportunity to try my hand at dormant seeding. I missed the window of opportunity last fall as we had an early snowfall and it never melted. This time I'll wait for mid - November, overseed and the fissures and cracks which develop in the soil should help greatly with new grass germination in the spring.
Anyone have experience with dormant seeding of grass seed?
Norman
steve mackay
>I got sucked into the vortex of the super-duper, genetic, nuclear, radio-active grass seed as-seen-on-TV from Gardener's Choice. Pricey but worth every cent. On a couple spots I got over-enthusiastic and dumped a whole handfull. I think thats what your asking. Once it came up and got to about an inch tall it kind of matted over during a heavy rain. Couple days of sun shine and it straightened out. Don't see a down side to "dumping" it on except for the $.
Lee Schierer - McKean, PA
>I've seeded areas twice in the fall just as the snow was starting to fall. When spring arrives, so does the new grass it works great. The normal wet weather of spring gives the new grass plenty of water and requires little labor.
Lee
Agree with Bill and John Re Straw
Vincent - Azle, Texas
>I have covered with straw both in the Fall and Spring when seeding. It makes a significant difference, a lot more of the seeds germinated and more of the seedlings survived, not to mention more seeds survived the birds. Worked best for me in the fall and the more I "Fluffed" the straw as I spread it around.
