How to Dry Cherry Boards
Jerry Draper
>My neighbor just had several cherry trees sawed into 4/4 X 8" x 8' boards(200bf). He has stickered the wood underneath his house. The walls are insulated so there is not a wide variation in temp. during the year. No moisture or condensation will be present.
How long will it take the lumber to dry and stablize? Should he circulate the air around the wood with a fan?
Advise on how to dry the wood would be appreciated.
Re: How to Dry Cherry Boards
Read Lee's Article *LINK*
>Everything you need to know is in this article from Lee Gridinger:
Air Drying Lumber, By Lee Gridinger
Get Heavy
>Cherry likes to "dance" as it dries, meaning that it will move and deform if not controlled. Have your friend put some serious weight on top of each stack. I use 5 6" solid concrete blocks for 4/4 8' boards.
If he hasn't done so already, make sure that the board ends are well sealed with paint or wax.
Ixnay on the anfay. Forced air circulation will promote faster drying but will increase the stress in the wood, so the stock will be more likely to twist, cup, or split/check. Just let them take their time.
mm
>Jerry,
I dry cherry outdoors, stickered, with a covering on top to keep the rain off. Even 8/4 will dry nicely in a year to equilibrium for these parts in East TN (around 12% or so). You didn't mention where you are in the country and what you will eventually do with the wood. If you build furniture, you may need it dryer than air dry.
Hard to visualize your situation but "underneath the house" and insulated sounds like a recipe for mold and humidity buildup. Is there plenty of ventilation or is the space airconditioned and heated? Air needs to move, but a fan blowing directly on the wood can actually dry it too fast.
If you want to read up on wood drying, a good book is Understanding Wood by R. Bruce Hoadley. A couple of excellent web forums have sawing and drying information - the knowledgebase on the WoodWeb probably already contains expert advice on cherry and questions are usually answered quickly.
http://www.woodweb.com/cgi-bin/forums/sawdry.pl
http://www.forestryforum.com/board/index.php#2
Great info.- many thanks to all
Jerry Draper
