Help me fix mistake in Cherry table top?
Doug in Denver
>I made a table top - 38" X 67" - that is all heartwood cherry 1" thick. It is made up of 6 boards. I used biscuits. When I went to square the ends, I stupidly forgot which biscuits were closer to which end, and cut ever so slightly into the holes where there is play for the biscuits. Did not actually reach the biscuits themselves. So I have a top with five little rectangular holes holes in one end, each the thickness of a slot cutter blade and maybe half again that long - pretty small. Of course I could fill them and nobody but me would ever know probably, but yuck, that idea does not appeal to me. All I know for sure is I really don't want to add bread board ends.
What other options are there that maybe I have not thought of? One option I thought of was since I have put a band of walnut near the bottom of each leg, and put a thin walnut band aroun the skirt bottom, I could route a real shallow groove and add a thin inlay strip of walnut around the whole edge, but would that gap at the corners as the top expanded no mattter how thin I make it? Any other ideas? Thanks.
