Zapping batteries to revive them *LINK*
Tom Dunlap
>Long story short...it didn't work that well for me. Two of my four DW 18v have just a little oomph pumped back into them.
The long story...
After reading the Instructable I decided to give it a shot.
My first round of playing Dr. Frankenstein..."That's 'Fronk-en-steen.' and trying to bring life to dead batteries was by using my battery charger. Using my mulitmeter I found that the quick charge output was 19.3v. After making a couple of pigtails with spade connectors for the batteries I checked the voltage of the batteries, they ranged from zero to 13.7v. The negative lead was clipped to the pigtail. The first zap was done with the charger set at 6v trickle charge. The output was 11.3v. The first couple of zaps were lively and the battery voltage came up a little. As I moved the charger voltage up the same thing happened. I would measure voltage, zap the battery, check voltage increase until it leveled off. Then go onto the next battery. The preceding one would go onto the charger.
After all four of the batteries were sparked and charged I put them into my drill. Two had really low voltage charge in them and two had about 13-15v. When I put the two good ones in the drill I could stop the chuck in high speed and slow it down a lot in low speed but just grabbing the chuck. The ooomph quickly faded from both batteries.
when I was messing around with this I kept voltage records at each stage. Those notes are at my shop but the actual numbers aren't that relevant.
My next step was to use my 110v Hobart Hobart Welders 500500A wirefeed welder. Using my multimeter I tested the voltage output at the various settings. The upper voltage was 30v. While I was reading about zapping the batteries several of the articles said that a higher voltage was needed. Since my charger only put out about 18v I decided to go up a level...More Power never hurts...does it? Now I'm really feeling like Tim Taylor...where's Al to laugh at me when I blow something up?
Before zapping I turned off the shield gas and flipped the wire feed driver off.
Basically, the same results with higher voltages after zapping the batteries with the welder. The two good batteries took a zap of around 17v before going in the charger.
After zapping and charging all four batteries I found the same results as with the battery charger. Low torque and low voltage.
The two good batteries are getting some use though. There was something in a couple of zapping articles that said that the batteries needed to be worked/discharged then recharged a few times to see if the zapping works. So far, it doesn't seem to help.
These batteries may have been damaged from spending their lives in un/over heated shops while I lived in Minneapolis/Denver/Atlanta/Dallas. Extreme temp conditions aren't good for batteries I've found out now.
Now I'm faced with a decision. The Lithium batteries for DW sound enticing. That means buying a new charger too and two batteries. Or...do I have the batteries rebuilt? Having a second drill/driver is enticing. Is it cost effective?
There is space in the shop now. I sent a charger and some 12v Panasonic batteries to another WC pal. Making space in my life for a reward...hmmmm...
It's too tempting to quote Elizabeth after her night with The Monster...but this is family broadcasting. Help yourself to some of the funniest, I think, lines written:
http://www.imdb.com/title/tt0072431/quotes
Zapping batteries
