>Does anyone else have a problem with viewing some messages? In the current set of messages, I can't see any of the posts about melamine. I can view the next series of posts on the writing desk. This happens all the time, but only with some messages.
>Hold down the left mouse key and roll your pointer over the message area. That's how I have to view messages occasionally. Reportedly it's a conflict between the software for the forum and Internet Explorer. Sometimes an invisible box from the advertising covers the message area on my computer, and I have to highlight the area without actually seeing what I'm highlighting and the copy and paste it into a text program like Word to read. Only three fourths of the world uses IE.
>As Kneale explained, this is a problem with the way our forum code interacts with Internet Explorer 6. I don't know about IE7. I don't know why only some messages fail to display. I have been trying to find a CSS/Perl guru (and a budget) to fix the problem, but so far, no luck. I'd attempt the fix myself, but I'd probably break the whole thing, as there is also HTML and Javascript involved. Besides, I'm looking into two other possible redesigns for our messageboards, either of which would render this issue moot. Please stay tuned, and try the workaround that Kneale suggested. Left-click where you expect to see the message and drag your mouse across the page. Presto, the message appears. It's a pretty easy workaround, but switching browsers is even better. No problems at all with Firefox.
I appreciate your patience. Sorry for the inconvenience.
>You should not have to cut and paste. Just highlighting it will make it show up. Hopefully IE 7 or 8 will fix some of the problems. Most people use IE because they don't know anything else, but IE causes more problems with the web than almost any other thing. It is almost the only browser that is not compliant with many of the web standards. If you look at the source code for most websites you will find a lot of places where there is code that basically says "here is the page as it should be to all of the current standards, and here is a bunch of hacks to make it work in IE". The best thing for the web will be the demise of IE6.
>I have this problem at work. I cannot see the message, but the list of messages in the thread displays just fine. For some reason, I figured out that if I left click over the message area (like when copying text), the message shows up. I'll admit, this is a pain, but at least I get to read messages during breaks at work!
>I downloaded Service Pack 3 yesterday and must have looked at several hundred posts since the download. All post have come up and I have been able to read them. Before yesterday, 50 percent or more of the posts would not appear and I had to do the hold down mouse key and move over the message area thing before the message would appear. I can't say for certain that SP 3 corrected the problem but since the download I've not had any problems reading any of the posts.
