Uses for a squirrel cage fan?
>I was given a squirrel cage fan of reasonable velocity. My first thought was to make a supplemental dust filter for use on the other wall of my shop. Any good ideas?
Any other thoughts for its use?
Re: Uses for a squirrel cage fan?
Downdraft table...
>Make an assembly table, and use pegboard for the top (enlarge the holes...)
Put furnace filters in between the top and base.
Then the squirrel cage blower in the base.
Re: I use mine...
Dale Lenz
>to blow over my wood heater during the winter, to dissipate the heat into the shop, does a good job. Only complaint I have, is the noise from the fan.
air cleaner
Bill Tindall, E.TN
>I mounted one between ceiling joists of shop with an air filter in front of it. Does well cleaning shop air of the fine stuff.
Heat distribution
>My old shop had a cathedral ceiling (such as it was :-) and the heat from the wood stove would rise up to the peak of the ceiling (no surprises there). So, I mounted a squirrel cage and motor up near the peak and directed the output into a plywood duct that carried the heated air all the way to the basement, which was our machine room. From there, it rose naturally through the large open stairwell back to the main floor of the shop.
>I was working on a down draft table but my fan burned up on the first try. I saved it to death. I also used one to improve the drying of my lumber. Set it up to circualte the air/heat through my home made solar kiln. I have one that I have used for many years as a home made air cleaner. Three coarse inlet filters and one fine outlet.
You are only limited by your imagination.
Some good ideas, Thanks
Caution! If it is a direct drive unit with the..
Art Silva
>impeller mounted on the motor shaft you probably will not have any problems. If it is a belt drive unit, and you do not have the original pulleys or motor you could have a problem. A squirrel cage wheel is referred to as "an overloading" wheel, so an Ammeter should be used to match amperage draw on the motor plate when selecting your drive speed. A variable sheave pulley on the motor would help. Good luck. Art
