Working with Melamine question
kennicka
>I am building a folding table for a friend (approx 34"L x 30" wide x 34" tall) based on a folding table I saw utilizing one sheet of plywood (3/4"). The table legs (2 - 30x34 pieces of plywood) fold down using piano hinges. Once open, two support wings fold out, also on piano hinges, and attach with some all-thread and a t-nut. A pretty clever design as it all folds into a square about 4" thick.
Anyways...on to my question. My friend wants his top to be melamine vice the plywood. All the melamine I have seen has a particle board core so I am wondering if I need to use anything other than #8 screws and glue when attaching the 3/4" x 2" strips (I am using red oak) to the bottom of the top that the hinges are attached to for the legs and the support wings? I hope my question is not too cryptic. Thanks. Tony
Re: Working with Melamine question
>Since the material you are using is a thin piece of plastic over chipboard, I would have little (read "None") confidence it its strength for a table, let alone its screw-holding ability. Were I doing this project, I'd be planning on laminating mica (HPL) on both sides of a 3/4 ply core.
I've used the stuff, but never on anything structural.
Dick Coers
>I suppose if you use a lot of screws..........But glueing to melaine is really tough. That stuff is really slippery, then add the idea that only about 5/8" of the screw will be in the particle board. Can you still bet Roo Glue? I think that worked on melamine. PVA glue will chip off melamine with almost no effort. I would suspect that the particle board will sag over time as well. I don't know what the table will be used for, or what loads it will see. Good luck.
Bill Howatt
>I have bought particle board screws at Home Depot in Canada and I assume they should be available in the US. They have a narrower root and a coarser thread than regular woodscrews.
Bill
Dan Mitchell
>I've used Roo Glue on melamine, in this case some kitchen drawers, seemed to work pretty well.
I agree with the others, I'd go with plywood/laminate for this project. More work & $$$, but if you expect the table to last, especially through the rigors of being moved/banged around, I'd forget the melamine.
Dan
