45 degree lck miter router bit
mike@American Sycamore
>Dear Woodworkers;
I am in need of using a 45 lock miter joint and I have real good luck on short sample set up pieces but running a 36" leg is very difficult. I am using my router table with small stock feeder. Do you think I would get a better cut going to a shaper cutter and using my big stock feeder on my 3hp shaper?? I would like to discuss this with someone that is getting a tight joint with either cutter. thanks,
Mike
Re: 45 degree lck miter router bit
Fred Davis
>Yes,
FredD
>have you tried with a router bit? What shaper, feeder, and brand of cutter are you using? Is it still a lot of set up to get one to come out correct? Waste a lot of material? Is the joint worth it?
thanks,
Mike
Rick L
Re: Much easier ways to do legs...
Rick L
>You like to torture yourself. I find it a lot simpler to use a 45 degree cut and the strapping tape folding method. I prefer the Merle clamp at MLCS but ant bandclamp will work.
Too many articles use the lock miter bit. I suspect they are paid by the router bit companies. I only use it on three sided fake box beams.
mdclor
>I also cut mine with the TS at 45*, but add a spline for alignment.
FWIW,
Merle
