Ryobi WDS1600 Drum Sander
Steven Bellner
>How in the world do you change the abrasive on the Ryobi drum sander? I have done this several times in the past, and every time I walk away from the machine swearing at whomever invented the clamp system on the drum. Any suggestions on getting the clamps to accept the abrasive? I changed it again tonight, and I thought it was all good, but then there was that horrible sound of the end of the abrasive whacking the inside housing as it came loose again. This is Ryobi abrasive, and is exactly the right length and dimension. I've got the makings of osteoarthritis in my right hand, and the right-side clamp must be the worst-designed piece of equipment I have ever seen.
Re: Ryobi WDS1600 Drum Sander
Gerald Caryl
>Clamping on this machines sucks, without a doubt...But if you know that this machine only likes to take very small depth of cuts, you can eliminate a lot of unnecessary changings. I have had a 60 grit roll on mine for about as long as my dog is old. I do not use the machine as an primary flatting device. I made a little prod that will hold the clamp open while I insert the roll. Make sure the roll is really tight also. I spread a little adhesive also on the drum. Hopes this helps. Gerry
Phil Thien
>I recently acquired a used one of these and was concerned about all the reports I read of difficulty changing the paper.
So tonight I changed my first roll (after reading your posting) and I guess I experienced beginners luck.
It did take me a while to understand that the right-hand clamp is a tensioner, as well. I didn't understand that you have to pull the entire thing up to the slot to insert the end of the paper.
Once I figured that out, it was quite straight forward.
If you do have a problem with your right hand, though, I can imagine that would make the task about 10x more difficult.
