Best top-coat for kitchen cabinets
Bill H - Evansville, IN
>I'm almost finished with a set (my first) of kitchen cabinets for our house. I'm beginning to stain and seal them. I'm learning that building them is the easy part. I was happy with the look I got from "General wipe-on oil based stain" over sanding sealer on test pieces. But I'm finding that it is difficult to get an even finish on a full panel.
I'm also finding the top-coat very challenging. In the past I've always just wiped on polyurethane or sprayed Deft out of a can. I borrowed a 2 stage HVLP (graco)and naively thought this would be the easy part with a fancy HVLP. I'm trying to spray General Arm-R-Seal oil & urethane top coat. Is this stupid? Do I need the protection of polyurethane for kitchen cabinets? Can anybody recommend a finishing recipe that gives decent results in the home shop for large projects like a kitchen full of cabinets (except for danish oils - not enough color for my wife)?
Thanks in advance,
Bill
Re: Best top-coat for kitchen cabinets
>Have you considered Minwax's Polycrylic? I used it to coat the interiors of my kitchen cabinets as they were already in place and I didn't want to stink up (or heat up) the house too much.
do what the Pro's do
Bill Tindall, E.TN
>Spray a catalyzed or pre catalyzed conversion varnish available from where ever your local cabinet shops get it. I get it from Sherwin Williams. And yes, if you use your kitchen it will need a finish that can stand up to cooking fumes, water and occasional washing.
And of course don't practice spraying it on your cabinet. Use a test panel(s).
Re: Best top-coat for kitchen cabinets *LINK*
>Bill,
I've "migrated" to nearly 100% waterborne top coatings, for their VOC compliance and ease of use. Since you're not set up to do 2-part UV cure polyester finishes, this is what I'll suggest.
First, pick up the phone and call Jeff Jewitt at Homestead Finishing at 216-631-5309 in Cleveland for recommendations. I have been using Enduro WB Poly-Clear & Enamel with stunning results on cabinetry. I went the extra step of adding cross-linker for high use tables, and the stuff goes down like glass with an HVLP. 2 or 3 coats (about 2 hours apart) will be all you need. I seem to remember the stuff is KCMA qualified, but ask Jeff.
Since you're going over oil stain (as I sometimes do) I'd recommend a light tie coat of freshly mixed dewaxed shellac. Jeff handles both the Enduro as well as others and a full line of shellac. Check out the Oxford Ultraseal WB shellac while you're there.
Disclaimer . . . .
Just very satisfied
PS: You can also go to the finishing forums on Jeff's site and learn much in a short period of time.
HomeStead - Jeff Jewitt
Fred Davis
>Without the right spray equipment , it's hard to say what is a good finish.
Nearly every painter and shop that did their own finish , including mine used Nitro Cellulose lacquer over sanding sealer and
then the catalyzed lacquers and varnish came out and I have switched to Pre Cat CAB over vinyl sealer the last five years.
Spraying a Deft finish on a entire set of cabinets in possible but tiring and expensive and not near as good as two coats of Deft's brushing lacquer.
I noted you stained over a sanding sealer which is backwards from from what I do , but who knows , maybe you had splotchy wood, like Maple or Cherry.
Contrary to what you may hear from amateurs, unless it frequently rains in your kitchen or you set it on fire, any form of Lacquer ,especially catalyzed one's give your cabinets plenty of protection and since it's Lacquer the best possible look.
Look into renting a airless rig or a air assisted sprayer and practice a bit with lacquer or buy a good animal hair brush and try the brushing lacquer that Deft makes, over a sanding sealer.
FredD
The best and easiest
Michael Dresdner
>Oil based polyurethane is both the most durable for kitchens, with great adhesion paired with high heat, chemical, stain and abrasion resistance, and is also the easiest to apply. Simply scrub it on with a nylon abrasive pad and wipe it off. Do one coat per day until you like the look. If you want an 'off the gun' sheen, buy the same stuff in an aerosol can from one of the big boys, like Varathane, and use that for the last coat, but personally, I'd do it all wipe on, then do a light rub once it is fully cured.
