Upside down computer display OT
Howard in Bethesda
>My wife hit a sequence on her keyboard that inverted the screen display and reversed the mouse action (move mouse up and cursor goes down). Any idea how to fix? Windows Vista.
Thanks
Howard
Re: Upside down computer display OT
Tell wife to stand on her head to view !
Galen V
>Must be why I am divorced!
Galen V
>I don't have Vista but if you yahoo or google search it list several things to try. I put in "Vista inverted display"
One may be as simple as hitting the ctrl, alt and arrow up key at the same time.
Other listing is to right click on a clear spot on your desktop, click properties,click setting, click advanced and then look for a command that may change your monitor setting to rotate.
Without Vista and the same monitor and driver I cannot check if they work.
Hope someone can give better fix but check these.
Sorry about the stand on your head but I see other on line solutions were flip monitor over. Must be late in the day.
Bill Howatt
>You might try looking in the Vista equivalent (sorry, I have XP only) of Control Panel Display. You may find under Properties or Advanced an option to rotate the display in 90 degree steps. This is usually done in software that controls your graphics card. You may also be able to find an icon in the tray on the lower right of your screen relating to graphics card settings as well.
Chuck W
>Right mouse click on the desktop to get display properties and look what is on the settings tab. There should be a box to check(or uncheck) to rotate the display 180 degrees.
Gary Evans Tallassee, TN
>I wonder why MS in their infinite wisdom would even make this an option? I can't think of any reason you might need to rotate the display.
Gary
>Suppose you mounted the monitor on the ceiling?
Thanks
Howard in Bethesda
>Thanks, hitting the ctrl, alt and arrow up key did it.
Howard
The reason.....
RobV
>.....they have that option is for when you connect the computer to a projector. If the projector sits on a table top it's fine, but if it's mounted to the ceiling you have to rotate the display 180 degrees. There is also an option for flip the display left to right for front vs. rear projection.
On a laptop these functions are usually access by holding the "FN" (function) key and hitting one of the F1-12 keys.
Galen V
>I have been in the hospital or clincal offices so much the past two years all I can say is some of my money is going to buy wide screen monitors they turn 90 degree upright to show my medical test and scan pictures. Some are on two monitors as split screens. Guess monitors at least need to rotate image 90 degree.
Maybe part of my problem is the screens got flipped 180 degree!
I'm cured by the ctrl, alt, arrow up and I been paying doctors for what?
Alexander Grigoriev
>This is actually not MS, but the display adapter manufacturer. And yes, the option is useful.
Ron Knapp
>I have a LCD monitor that pivots and this function is very useful. Reading a PDF document in its natural mode make for very easy reading. I only buy LCD monitors with this 'Feature"
Re: The reason.....
>Thanks Rob,
I had no clue as to the usefulness of such a function.
It's always good to learn new stuff.
Gary
Like the iPhone
>Yes, many LCD monitors can sense the orientation of the screen relative to the stand and tell the computer to adjust the picture.
Even cooler is the iPhone which senses it gyroscopically (is that even a word?)
Hold the iPhone vertically(normal) and the screen appears vertical.
Tilt it to the left or right so it's horizontal and the display magically turns.
Turn it completely upside down and it asks you if you've fallen down and asks if you are okay...... no, I'm just kidding about that last part :)
Happy Woodworking!
