Need dust collector help please...
David G. Sparks
>I have a 2 hp Dust Boy type dust collector, the kind where the motor and housing sit on top of a 55 gal. drum. I bought it used and the motor is not the original one. I've recently had to have the motor repaired and am reassembling everything now. I can't decide the best place on the motor shaft to lock the impeller in place. I'm guessing the center point of the impeller vanes should be in the center of the inlet port. Is this right? I know Delta and Dayton make similar units to the one I have. If one of you has a collector like mine, could you please take the inlet hose loose and see where the impeller blades line up in relation to the inlet hole? It would be a big help to me. Thanks in advance.
Re: Need dust collector help please...
Phil Thien
>Impeller as close to the motor as possible w/o rubbing on the housing.
Thank you!
davidgsparks
