Formica
Formica
Formica
Don at Central Illinois
>I have a chance to get some teller units for our credit union and I believe the finish is either formica or something similar. Is it possible to sand enough to rough up the finish and then spray paint to whatever color I want? I've never tried it, so I thougt I would ask all of the experts. TIA.
Re: Formica
Re: Formica
Keith Newton, LR, Arkansas------WebKitFormBoundary
>Yes you can do that. I have not done it for a work surface though, so I don't know how well it will hold up under heavy service.
Just in case you don't know, it can be removed and replaced. I use a heat gun, and sword to get it off. It is a lot easier with a helper.
Re: Formica
Re: Formica
Fred Davis
>To remove Formica quick and easy , just use a sharp chisel to raise a edge and using a can of lighter fluid squirt it under the plastic as you raise it , pops right off.
FredD
Re: Formica
Agree with Fred
>Even if you sand it, HPL (high-pressure laminate) isn't likely to hold paint well. Don't take my word for it though; try it and see. It is possible to stick new HPL over existing HPL, using contact cement, but I think the best solution would be to remove and replace it. For a high-traffic, high-wear surface like a teller window, I think you need the long-wearing properties of HPL, or solid-surface material. More work and expense up front, but it'll pay for itself in the long run.
Ellis Walentine, Host
Re: Formica
Sword? Wow! Gotta get one!
Hank Knight
Re: Formica
Re: Agree with Fred
>Thanks, all. It may be cheaper to buy a new unit than go to the expense of the free stuff. Guess I'll have to do some more analysis.
Re: Formica
Don, a question
Gary Camp, Bend, Oregon
>Are you getting the Teller units for your own use and just want a different color? Are you redoing them for a your credit union, as a job? That is not clear to me and it makes a difference. I have had HPL repainted, it was realtivly successful. I believe that it held up a couple of years before it started to wear through. This was in a large public restroom at the ski area I work at. Our guest counts during the time frame of the painted laminate were in the 500,000 per year range. I know that a local bank also had teller window counters painted in that time frame, I did not keep track of how that project faired. From my prospective, if it were for my own use I might try paint depending on use and location. Of course if it were going in my shop I would just live with what ever was there.
glc
