Marketry and stain/dye
Joe Vultaggio
>How do you darken the background wood that has some marketry in it without darkening the marketry wood???
Joe Vultaggio
Re: Marketry and stain/dye
Tony - Memphis
>That's a good question! I just read an article recently by Jeff Jewitt where he "painted" inlay with shellac before staining a piece. Seems like I have seen that somewhere before as well. Fine artist brushes will be needed (and patience). I'm not sure I'm steady enough to stay in the lines, but I haven't tried it yet. My wife is an artist, so I may get here to do it when I need it.
Tony
Alan Young
>Tony is correct.
I used a small artist's brush dipped in Sealcoat ie dewaxed shellac. Coat the lighter wood or what ever wood you don't want altered by the stain. Let dry then stain the surrounding areas and wipe away. any over flow to the shellacked areas should wipe clean... Apply chosen top coat-varnish,lacquer poly...
Alan
